RuneAudio+R e3
Re: RuneAudio+R e3
Postby J4K » 28 Mar 2020, 13:52
Hi Rern,
ceejayemm Just beat me to it, Everything works fine until I change the l2s module, then reboot and stuck on logo screen.
Very fast to boot though, so still very impressed.
Can anyone tell me the difference between iqaudio pi dac+ and iqaudio dac+ in l2s Module?
And also what do the different settings in Sound Profile: Custom Mean?
Currently back on Re2 listening to Megadeth - Anthology: Set The World Afire.
It Sounds Awesome on RuneAudio.
J
J4K
Re: RuneAudio+R e3
Postby ceejayemm » 28 Mar 2020, 13:59
Rern
AS requested mpd.conf is attached.
Chris
mpd.zip
(489 Bytes) Downloaded 556 times
ceejayemm
Re: RuneAudio+R e3
Postby ceejayemm » 28 Mar 2020, 14:14
Rern
It only seems possible to add one Web Radio to e3, the plus (+) button to add more has disappeared.
Chris
ceejayemm
Re: RuneAudio+R e3
Postby rern » 28 Mar 2020, 14:28
Re: RuneAudio+R e3
Postby klassikmann » 28 Mar 2020, 15:25
klassikmann
Re: RuneAudio+R e3
Postby ceejayemm » 28 Mar 2020, 15:55
Rern
Output of commands as requested in attached zip file. The final command was obviously expecting a different parameter so only the command help has been output..
Chris
ruine_e3_2.zip
(1.31 KiB) Downloaded 570 times
ceejayemm
Re: RuneAudio+R e3
Postby rern » 28 Mar 2020, 16:23
@ceejayemm and @J4K,
1. Start over from writing the image file to SD card.
2. Settings > Addons > RuneAudio+R e3 > Update
3. Setup I2S module
IQaudIO DAC+ and IQaudIO Pi-DAC+ use the same driver.
Custom sound profile is for tweaking system parameters which may improve sound quality. Tap top-right ? button and google the names for details.
Re: RuneAudio+R e3
Postby ceejayemm » 28 Mar 2020, 17:20
Rern
Ok that last update and the sequence of install /setup steps seems to have cured my problems and I have a working RA R-e3 installation. A minor problem for another day is that the Web Radio library does not update automatically when you add a new radio station. Is there any way to EXPORT a set of radio stations ? There is a means to import them via a plugin but I don't see a way to export them when, for example moving from R-e2 to R-e3
Thanks for you hard work on this.
Chruis
ceejayemm
Re: RuneAudio+R e3
Postby R101 » 28 Mar 2020, 19:36
Thanks rern, I have it running with fixed IP over wifi, but it still takes a lot of manual configuration. The setup form ignores the fixed IP tick and creates a file in netctl which is DHCP, with the IP shown as the gateway address, and the gateway address unknown. Other lines seem to be wrong too, but after pasting in a working file, I found the wifi needed to be turned on in settings, so that might have affected the setup form?
Wireless Samba shares did not work, as the smb.conf file is still missing the zero off the wlan entry.
It takes a couple of minutes for the playback page to appear via wifi after startup. No problem with a wired connection.
The cover placeholder appears in the album track folder, even when cover art is turned off in settings. This takes up a lot of space on a small screen.
Re: RuneAudio+R e3
Postby J4K » 28 Mar 2020, 19:50
Thankyou rern,
Everything works great now :)
J
J4K
