RuneAudio+R e3
Re: RuneAudio+R e3
Postby belgarath0815 » 20 Apr 2020, 00:08
Update 0418 broke browse by folder
Sorting Order is wrong
Tried to rebuild the database, didn't help.
Regards,
Edit: looks like not only browse by folder is affected, also some files are in the correct order..
belgarath0815
Re: RuneAudio+R e3
Postby maravtatet » 20 Apr 2020, 01:05
Hi everyone,
I'm testing this release on a RPi1, and I'm struggling with network share configuration through your UI.
I'm trying to add a source on my local network which is 192.168.2.201 and I consistently receive a message saying IP host doesn't exist.
Yet, using ssh and direct mount command, I was able to mount the network share.
Is this a known issue ?
Thanks in advance for your time
maravtatet
Re: RuneAudio+R e3
Postby R101 » 21 Apr 2020, 10:38
Re: RuneAudio+R e3
Postby R101 » 21 Apr 2020, 10:47
@rern
If an album track is playing and I go to Library and replace/play a radio station, the track time from the album remains on the playback page.
Time, and Webradio elapsed, are disabled in the playback display menu..
Playing at just 44.1khz
Postby vennesch » 21 Apr 2020, 18:12
Hello, any ideas why I can only play music at 44.1khz? I got a Hifiberry DAC+ and Tidal Masters account. Via BubbleUpNP and Linn Kazoo I got the same results.
On Qobuz I get 24 bit on 96.0khz and 2.49mb/s
On Tidal I get ''f bit'' on 44.1khz and 320kb/s
What causes Tidal to be inferior on Rune?
P.S. no cover art or Artist info in Qobuz
P.P.S. What the heck is ''f bit''? Even Google seems to have never heard of it.
P.P.P.S. did a fresh install to be sure, no difference
vennesch
RuneAudio+R e3 ssh public key auth not working
Postby valemax » 22 Apr 2020, 19:57
Hi all, first post here so thanks for everything!.
Now, back to business, setting public key authentication fails on R e3 (and failed on R e2 too), because /root directory has 775 permissions and sshd does not like when the home directory is readable to all.
There are two solutions, the most logic would be to set 700 on /root, or one can set "StrictModes off" in sshd_config.
Before I go on and break something, is there a reason why /root has 775 or is just a distraction and I can set 700 and live happily thereafter?
valemax
Re: RuneAudio+R e3
Postby INRI » 23 Apr 2020, 10:30
How can I edit the library over ssh? Who can help me? Thanks.
I found it myself: /srv/http/data/webradios
INRI
Re: RuneAudio+R e3
Postby rern » 23 Apr 2020, 12:20
Re: RuneAudio+R e3
Postby kirx » 23 Apr 2020, 18:58
@rern
Many thanks for the continuous improvement of RuneAudio. :-)
Everything works like a charm in my setup (RPi 3B+ along with the TDA1387x8 USB-DAC)
Keep on going! :D
Respectfully,
Kir.
kirx
Re: RuneAudio+R e3
Postby GlennS » 27 Apr 2020, 08:04
GlennS
