RuneAudio+R e3
Re: RuneAudio+R e3
Postby kailua » 29 Apr 2020, 14:02
I just built RuneAudio+Re3 via the DIY method. Everything went fine with running create-alarm.sh on my desktop. But after inserting the SD card into my Pi3 I saw a lot of messages in the journal that some daemons (e.g. timedate) could not be started.
It turned out that the service responsible for creating the temporary file directories could not start because of unsafe path transitions.
I checked the permission on / and it had 700 owned by the alarm user and not root. I don't know where that came from but setting the correct permissions (755) and ownership (root) fixed the problem. Also, I tried it two times with the same result. So, that might be a permanent problem.
Just to let you know if you run into similar problems.
Cheers
kailua
Re: RuneAudio+R e3
Postby 6b4g » 30 Apr 2020, 15:14
Thanks very much for this new release of Runeaudio!
I tip from my side. I had to add "vers=1.0" in the "Options" field when mounting my NAS share using CIFS in order to get it mounted.
best regards,
Kees
6b4g
Re: RuneAudio+R e3
Postby rern » 01 May 2020, 13:18
Re: RuneAudio+R e3
Postby rern » 01 May 2020, 14:27
This cannot be updated via Addons as usual. Please download updated image files from links in the .
Backup existing data and settings: Menu > Settings > Backup/Restore Settings
Renderer
Spotify Connect -
Streamer
Sync Streamer - - Synchronous multiroom audio player
Streamer - via http port 8000 (e.g., 192.168.1.111:8000)
Dedicate a CPU core for MPD
Improve volume control
Auto expand root partition (remove /boot/x.sh to skip)
Upgrade kernel and packages
Re: RuneAudio+R e3
Postby kailua » 01 May 2020, 15:59
I use ArchLinux. But, I think I found the reason for the wrong permission. I used the KDE filemanager to mount the partitions of the SD card which mounted them with user rights. Also I formatted the partitions with the disk utility. I think that the first or a combination of both caused the wrong permission of / on the SD card.
Cheers
kailua
Re: RuneAudio+R e3
Postby klassikmann » 01 May 2020, 17:53
klassikmann
Re: RuneAudio+R e3
Postby cmh714 » 01 May 2020, 19:13
Nevermind....finally on the tenth or so time it poped up
Update 20200501
Same as above....also I cannot get the MPD settings page to render
Re: RuneAudio+R e3
Postby R101 » 01 May 2020, 19:17
Hi rern,
The pause button has reappeared on the Webradio playback page.
All the usual problems getting the wifi working, plus I had to enable netctl. Is this version for wired connection only?
Re: RuneAudio+R e3
Postby eggshell » 02 May 2020, 03:16
The best just got better! Thanks, it is working great. For those who can't render the MPD page. I had the same issue. I changed back to the 3.5mm audio out, rebooted, then switched to i2s and rebooted. Voila MPD page renders.
Thanks Rern for your amazing player.
Andreas
eggshell
Re: RuneAudio+R e3
Postby rern » 02 May 2020, 03:20
