RuneAudio+R e3
Re: RuneAudio+R e3
Postby vaughan » 14 May 2020, 12:52
Hi rern, just to let you know that there's a very minor typo in context.js - it contains 'Fetcth' rather than 'Fetch'.
Many thanks for all your hard work on this,
Vaughan
vaughan
Re: RuneAudio+R e3
Postby simon » 14 May 2020, 17:28
New Rune user, have downloaded +R e3 and updated to latest version on my Pi4. I have tried enabling AirPlay but although it shows On on the system screen, when I leave and come back, it is off again. Its like its either not able to start or option is not saved.
I couldnt find any posts that might explain the behaviour.
simon
Re: RuneAudio+R e3
Postby rern » 15 May 2020, 07:04
Re: RuneAudio+R e3
Postby simon » 15 May 2020, 10:06
simon
Re: RuneAudio+R e3
Postby simon » 15 May 2020, 10:22
simon
Re: RuneAudio+R e3
Postby Gabriel Syme » 16 May 2020, 15:41
I am running this version on a Pi 3. The Pi 3 also has a IQ audio DAC connected via the header. The server is only used for music. In 24 days since I last rebooted it, I have 21 Zombie processes showing up in Top. Is anyone else experiencing this?
Gabriel Syme
Re: RuneAudio+R e3
Postby rern » 17 May 2020, 03:07
Re: RuneAudio+R e3
Postby rern » 17 May 2020, 12:48
Update 20200517
CoverArts and Bookmarks
- Preserve aspect ratio everywhere except Browse by CoverArt
- Note: Existing bookmarks and webradios are square (replace if needed)
- Improve Tap to rotate image in replacing dialog box
- Very wide or very tall images are applicable
- Improve layout for time + coverart or coverart + volume
Toggle time-volume knob (top-left corner)
- Resize coverart and guide
- Switch buttons/icons to any display combinations
Overlay guide
- Always maintains the same size and aspect ratio as coverart
- Maintain icon size
- Note: Tap/drag applies commands and auto-hide guide
Progress/elapsed bar
- Only when time is hidden
- Tap/drag like time knob
Volume bar + up-down
- Only when volume is hidden and not disabled by MPD
- Always hidden
- Tab bar = show current value and bar then tap/drag
- Tab up-down = -/+ and show value and bar
- Auto-hide in 3 seconds
Playback display
- Improve inter-locking on/off/disabled for any combinations
Misc.
- Fix AirPlay bugs
- Add Import Playlist addon
Re: RuneAudio+R e3
Postby Gabriel Syme » 18 May 2020, 01:15
here is the list of zombie processes:
ps auxwww | grep 'Z'
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
robert 4080 0.0 0.0 2528 504 pts/0 S+ 00:13 0:00 grep --color=auto Z
root 5678 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 6954 0.0 0.0 0 0 ? Z Apr22 0:00 [sudo] <defunct>
root 7013 0.0 0.0 0 0 ? Z Apr22 0:00 [sudo] <defunct>
root 7145 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 7207 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 7273 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 7311 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 7327 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 7332 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 7679 0.0 0.0 0 0 ? Z Apr28 0:00 [sudo] <defunct>
root 8373 0.0 0.0 0 0 ? Z May15 0:00 [sudo] <defunct>
root 8483 0.0 0.0 0 0 ? Z May15 0:00 [sudo] <defunct>
root 8495 0.0 0.0 0 0 ? Z May15 0:00 [sudo] <defunct>
root 8666 0.0 0.0 0 0 ? Z May15 0:00 [sudo] <defunct>
root 8681 0.0 0.0 0 0 ? Z May15 0:00 [sudo] <defunct>
root 8783 0.0 0.0 0 0 ? Z May15 0:00 [sudo] <defunct>
root 13039 0.0 0.0 0 0 ? Z Apr27 0:00 [sudo] <defunct>
root 13220 0.0 0.0 0 0 ? Z Apr27 0:00 [sudo] <defunct>
root 15121 0.0 0.0 0 0 ? Z May16 0:00 [sudo] <defunct>
root 15132 0.0 0.0 0 0 ? Z May16 0:00 [sudo] <defunct>
root 15185 0.0 0.0 0 0 ? Z May16 0:00 [sudo] <defunct>
root 17139 0.0 0.0 0 0 ? Z May16 0:00 [sudo] <defunct>
root 22514 0.0 0.0 0 0 ? Z May17 0:00 [sudo] <defunct>
root 22624 0.0 0.0 0 0 ? Z May17 0:00 [sudo] <defunct>
root 22627 0.0 0.0 0 0 ? Z May17 0:00 [sudo] <defunct>
root 22985 0.0 0.0 0 0 ? Z May17 0:00 [sudo] <defunct>
Gabriel Syme
Re: RuneAudio+R e3
Postby simon » 19 May 2020, 15:22
simon
