RuneAudio+R e3
Re: RuneAudio+R e3
Postby rern » 02 Jun 2020, 05:44
Re: RuneAudio+R e3
Postby cycl157 » 02 Jun 2020, 06:24
cycl157
Re: RuneAudio+R e3
Postby rern » 02 Jun 2020, 07:48
Re: RuneAudio+R e3
Postby klassikmann » 02 Jun 2020, 11:35
klassikmann
Re: RuneAudio+R e3
Postby stefanm » 03 Jun 2020, 04:55
I've installed this from the link in the first post on this thread.
On a pi4, I can't connect wireless to my router, my SSID shows up but after entering the password I receive connection failed
I get similar issues with volumio and moode, on volumio it won't connect to WiFi at all, though it works on a dongle without a problem. On moode if I create a config txt before first boot it connects to WiFi on start up, but WiFi disappears after selecting my boss dac and rebooting.
So I know the onboard WiFi is functioning.
Can I set it up manually on rune?
It's not allowing my to select the correct time zone either, not sure if that is part of the issue?
stefanm
Re: RuneAudio+R e3
Postby rern » 04 Jun 2020, 02:58
Update 20200604
Add
- Animated GIF support for coverarts and bookmarks
- Smooth volume (incremental change)
Fixes
- Missing embedded coverarts on track change
- Albums or directories with ' ", quotes/double quotes, in browse by CoverArt
Experimental
- Bluetooth audio
Notes:
- Coverarts as separate files are loaded a little faster.
- Bluetooth is still choppy, broken into pulses. Someone with a solution please share.
Re: RuneAudio+R e3
Postby klassikmann » 04 Jun 2020, 08:39
klassikmann
Re: RuneAudio+R e3
Postby rern » 04 Jun 2020, 14:02
Re: RuneAudio+R e3
Postby eggshell » 04 Jun 2020, 15:03
Thank you for the smooth volume control. Works just like I was thinking it should. Not sure how you do your magic, but keep doing it.
Andreas
eggshell
Re: RuneAudio+R e3
Postby Beelzebassie » 04 Jun 2020, 15:30
Ooh! Browsing Library-folders is a lot smoother/faster.
Thx, rern!
Beelzebassie
Users browsing this forum: No registered users and 51 guests
