RuneAudio+R e3
Re: RuneAudio+R e3
Postby klassikmann » 05 Jun 2020, 16:57
klassikmann
Re: RuneAudio+R e3
Postby neckbeard » 05 Jun 2020, 17:38
neckbeard
Re: RuneAudio+R e3
Postby klassikmann » 07 Jun 2020, 12:44
Update RuneAudio+R e3 20200607
The two problems
a) "ghosts/covenants"
b) "long coverart file names"
have been resolved.
klassikmann
klassikmann
Re: RuneAudio+R e3
Postby stefanm » 07 Jun 2020, 15:32
I've been trying to get this working on a pi4 with a boss DAC, I can't get the WiFi to connect or even a dongle (not showing up).
The DAC is the latest HW revision 1.7, I've been in touch with Allo, for some reason I'm getting WiFi issues with everything, rune, moode and volumio, right now I'm running volumio with a dongle. I can operate moode via WiFi until the ethernet is unplugged, then it automatically goes to the hotspot.
I'm thinking of trying add the WiFi manually, should I just follow a guide for archlinux? Such as this http://www.linuxandubuntu.com/home/how- ... g-terminal
Or should I try some other suggestion?
stefanm
Re: RuneAudio+R e3
Postby hermano » 09 Jun 2020, 13:50
Quick query and of course, thanks to developers and all who contribute. using PI4 and RuneAudio+R e3; recently returned to Rune after a time with Moode.
Issues I am having are:
1.browsing by 'Date', is there any way to limit view to years only. Some showing day and month. I assume this is in the tags but other systems just show year and not day/month.
2. On first 'play' there is no sound. Song 'playing ' as time countdown etc but no sound. However if I stop then start again it plays...every time.
Neither of these are deal breakers and I am enjoying Rune again. Keep up the good work.
hermano
Re: RuneAudio+R e3
Postby Sagnasty » 09 Jun 2020, 17:34
Hi, running e3 20200607 on a Pi 3 Model B Plus Rev 1.3 with HiFiBerry DAC+ Pro and a Synology DS718plus NAS as the NFS source. I may have found an issue with having more than 34 albums for a single artist. in my case, I had two library instances with an artist which had more than 34 albums.
Steps to reproduce: when traversing my library and then pressing on the artist (with more than 34 albums), the system would attempt to display the album list and then the display would hang. By refreshing the browser (Firefox 77.0.1 - 64-bit) or from my Iphone XE, the system display would then return to the default screen without a need to restart the system. Updating / rebuilding the library resulted in the same behavior. I originally thought it was a library file issue on my side, but I confirmed that it is simply the number of albums for an individual artist creating the issue.
I hope this helps.
Really liking RuneAudio+R e3 by the way - keep up the good work Rern!
3 x Raspberry Pi 3B+ Rev 1.3 > HiFiBerry DAC+ Pro
1 x Raspberry Pi 3B Rev 1.2 > HiFiBerry DAC+ Pro
Synology DS718+
Sagnasty
Re: RuneAudio+R e3
Postby Garrido33 » 09 Jun 2020, 17:49
Hi Rern
Hi Klassikmann,
Ghost coverarts and other problems with coverarts totally solved here. Works fine now, thanks.
A small display problem (not new) on my local official 7" screen : when I activate the bars on screen in the playback display, the display is partially hidden underneath (oversized for the available space). No problem with the full screen display (no bars).
Thanks again for your work.
Garrido33
Garrido33
Re: RuneAudio+R e3
Postby rern » 10 Jun 2020, 03:15
Re: RuneAudio+R e3
Postby rern » 10 Jun 2020, 14:05
Re: RuneAudio+R e3
Postby Sagnasty » 10 Jun 2020, 15:03
Upgraded to e3 202006101
Reboot
test library with single album artist with 35 albums (comprising three total artists)
Rebuild entire database (test library with artist / 35 albums)
via putty session, successfully executed the following commands:
mpc find album "ALBUM NAME" artist "ARTIST NAME"
mpc find album "ALBUM NAME" albumartist "ARTIST NAME"
Test results:
Viewing library via album or genre worked fine.
Viewing library via artist or albumartist generated same issue as reported.
Synology DS718+
Sagnasty
