RuneAudio+R e3
Re: RuneAudio+R e3
Postby klassikmann » 05 Apr 2020, 08:54
klassikmann
Re: RuneAudio+R e3
Postby rern » 05 Apr 2020, 09:19
Update 29200405
WebRadio switches to UPnP mode - Fixed.
I2S setting bug - Fixed.
Re: RuneAudio+R e3
Postby klassikmann » 05 Apr 2020, 09:48
klassikmann
Re: RuneAudio+R e3
Postby ceejayemm » 05 Apr 2020, 09:50
Rern
I am afraid your fix this morning (29200405) for Web Radios appearing as UPnP DO NOT fix my problem (reported 1st April) with web radio stations being sourced via MininServer.
Also the order of items on the System page seems to have been reversed, with Features at the top and Environment at the bottom.
Chris
ceejayemm
Re: RuneAudio+R e3
Postby vennesch » 05 Apr 2020, 10:11
With latest update my upnp/Tidal problems are gone! I can play everything again! Weird thing is that upnp only works when I leave the tidal credits blank.
One more ''problem'' I can only up to 320kbps...
On any other device I can play Flac files (Tidal hifi tier). It does not matter if I set upnp to lossless, high or low, it just behaves the same.
vennesch
Re: RuneAudio+R e3
Postby rern » 05 Apr 2020, 11:57
Re: RuneAudio+R e3
Postby klassikmann » 05 Apr 2020, 12:25
klassikmann
Re: RuneAudio+R e3
Postby klassikmann » 05 Apr 2020, 12:56
klassikmann
Re: RuneAudio+R e3
Postby R101 » 05 Apr 2020, 13:21
Just to confirm - Webradio still does not display the station name when it is playing if no metadata is contained in the stream. The station name is there when the station is added to the playlist, but it vanishes when play is pressed.
Re: RuneAudio+R e3
Postby rern » 05 Apr 2020, 13:28
