RuneAudio+R e3
Re: RuneAudio+R e3
Postby klassikmann » 05 Apr 2020, 13:45
klassikmann
Re: RuneAudio+R e3
Postby ivicah » 05 Apr 2020, 17:35
With latest update i cant use Rune audio app.
ivicah
Re: RuneAudio+R e3
Postby AndyF » 05 Apr 2020, 18:13
@klassikmann
Can you give an example-URL for one of your radiostations? On my setup all webradios work fine without UPnP-detection.
Regards, Andy
AndyF
Re: RuneAudio+R e3
Postby klassikmann » 05 Apr 2020, 18:55
klassikmann
Re: RuneAudio+R e3
Postby AndyF » 05 Apr 2020, 19:51
AndyF
Re: RuneAudio+R e3
Postby ceejayemm » 05 Apr 2020, 20:11
Rern
Sorry this is the first chance I have been able to get back to you since earlier today.
You asked "Is there a reason to relay your Webradios via MininServer?"
I have been doing this since the early days of RA 0.3/0.4 as a way to be able listen to the higher quality 320kb UK BBC national radio streams. I could also do these using RA+Re2 as well. These BBC streams are only available in the UK where I live and I need to use a very specific URL that couldn't originally be handled by RA and had to be served via MinimServer. I have done this successfully for several years until the recent changes in RA+Re3.
R101 provided a couple of alternative url steams for some of these stations earlier in the week. I have also found a website which can provide .m3u8 FILES (not direct url streams) which I can download and play in VLC. I can also import these files into RA+Re3 web radios by placing the files in /srv/http/data/webradios however I cannot get them to play. The files are typically called bbc_radio_two.m3u8 and contain:
#EXTM3U
#EXT-X-VERSION:3
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=339200,CODECS="mp4a.40.2"
http://as-hls-uk-live.bbcfmt.hs.llnwd.n ... ewind.m3u8
I can play the MinimServer BBC streams as a UPnP stream, not as a web radio station, and once one of these streams starts there is a blue UPnP banner across the bottom of the browser screen (as uploaded previously) which prevents me getting back to the Library, Playback and Playlist screens thus loosing control of RA unless i open an SSH connection and enter the 'mpc clear' command' - not very friendly at all.
Regards.
Chris
ceejayemm
Re: RuneAudio+R e3
Postby R101 » 06 Apr 2020, 10:55
ceejayemm,
I am still not clear why you don't just get the streams direct from the BBC, if you are in the UK?
There is a complete list of URLs here:
https://www.hifiwigwam.com/forum/topic/ ... -stations/
Re: RuneAudio+R e3
Postby vennesch » 06 Apr 2020, 13:22
vennesch
Re: RuneAudio+R e3
Postby rern » 06 Apr 2020, 14:04
Update 20200406
WebRadio vs UPnP
- Fixed.
- WebRadios which URLs contain internal IP - UPnP must be disabled.
WebRadio station name
- Fixed.
Progress bar while Time knob hidden
- New
- Tap / Drag to select position to play - like with Time knob
Re: RuneAudio+R e3
Postby ivicah » 06 Apr 2020, 16:49
ivicah
Users browsing this forum: Google [Bot] and 14 guests
