RuneAudio+R e3
RuneAudio+R e3
Postby rern » 27 Mar 2020, 14:13
Re: RuneAudio+R e3
Postby cmh714 » 27 Mar 2020, 15:27
Thank You Rern!
Re: RuneAudio+R e3
Postby s.k. » 27 Mar 2020, 15:37
I manage to build the image from scratch, for my Pi2.
I’m very impressed from UI speed & response.
Question:
Does anyone managed to setup a static IP ?
I’m trying to set it up, but the configuration menu doesn’t popup.
Rern great job!
Much appreciate for you efforts.
Thanks again !
Stavros
s.k.
Re: RuneAudio+R e3
Postby klassikmann » 28 Mar 2020, 08:55
Issue
Library Display: Setting "Sort by artist" doesn' work.
"thumbbyartist" in data/system/display is set, but no visible change in coverart window.
=> Click on any thumbnail generates a "No data in this location" pop-up.
Typo
Playback Display: "Share+Bio buttuns"
klassikmann
klassikmann
Re: RuneAudio+R e3
Postby rern » 28 Mar 2020, 10:58
@klassikmann,
They're fixed.
To be release with next update.
Re: RuneAudio+R e3
Postby klassikmann » 28 Mar 2020, 11:07
klassikmann
Re: RuneAudio+R e3
Postby rern » 28 Mar 2020, 11:29
Re: RuneAudio+R e3
Postby wim-nl » 28 Mar 2020, 12:49
[quote="s.k."]I manage to build the image from scratch, for my Pi2.
Question:
Static IP is provided by your router, not by rune.
wim-nl
Re: RuneAudio+R e3
Postby ceejayemm » 28 Mar 2020, 13:32
Downloaded and installed RA+Re3 to a RPI3 (where I have run all previous versions of RA). On first boot I can access the system and moved to the System screen to change the Time Zone (Europe/London), turn off Wireless option, browser on PI and add AudioDAC+ sound card. System requests a reboot but on restart just displays large Rune Audio logo. Pointing browser to http://raconservatory/index-settings.php?p=system allows me to see boot log. The shows an exception towards the end of the boot process
Mar 28 12:18:25 runeaudio systemd[1]: startup.service: Succeeded.
Mar 28 12:18:25 runeaudio systemd[1]: Finished RuneAudio+Re Startup.
Mar 28 12:18:25 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=startup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 12:18:25 runeaudio audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=startup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 12:18:25 runeaudio systemd[1]: Reached target Multi-User System.
Mar 28 12:18:25 runeaudio systemd[1]: Reached target Graphical Interface.
Mar 28 12:18:26 runeaudio mpd[789]: exception: Error in /etc/mpd.conf line 29
Mar 28 12:18:26 runeaudio mpd[789]: exception: nested: Missing closing '"'
Mar 28 12:18:26 runeaudio systemd[1]: mpd.service: Main process exited, code=exited, status=1/FAILURE
Mar 28 12:18:26 runeaudio systemd[1]: mpd.service: Failed with result 'exit-code'.
Mar 28 12:18:26 runeaudio systemd[1]: Failed to start Music Player Daemon.
Mar 28 12:18:26 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mpd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Mar 28 12:18:26 runeaudio systemd[1]: Started MPD idle.
Mar 28 12:18:26 runeaudio systemd[1]: Startup finished in 5.536s (kernel) + 43.851s (userspace) = 49.387s.
Can anybody help me get this new version to run please ? Full log file attached as well.
Chris
rune-e3_1.zip
(13.37 KiB) Downloaded 564 times
ceejayemm
Re: RuneAudio+R e3
Postby rern » 28 Mar 2020, 13:47
@ceejayemm,
Can you SSH to your system and get the content of /etc/mpd.conf ?
