RuneAudio+R e4
Re: RuneAudio+R e4
Postby klassikmann » 29 Jul 2020, 20:27
Hi Andy,
I deleted all my coverarts. Then I generated exactly one new thumbnail.
==> Same problem ()
klassikmann
klassikmann
Re: RuneAudio+R e4
Postby wiloma » 29 Jul 2020, 21:05
wiloma
Re: RuneAudio+R e4
Postby belgarath0815 » 30 Jul 2020, 00:21
Last Update completely broke browser by folder for me, had to remove the mountpoint and rebuild the database. It's working again but now on some folders the tracks are not sorted correctly, an issue I already had after an update on e3
I'm starting to wonder what's causing all this problems with updates, maybe it's the update mechanism itself?
I don't have any problems with thumbnails for example...
Regards,
belgarath0815
Re: RuneAudio+R e4
Postby rern » 30 Jul 2020, 01:13
Re: RuneAudio+R e4
Postby klassikmann » 30 Jul 2020, 16:33
klassikmann
Re: RuneAudio+R e4
Postby eggshell » 30 Jul 2020, 18:39
After latest update I've noticed that on the volume "wheel" if you make a change up or down of less than 10 it makes no change to the volume. Once you select a bigger than 10 change it adjusts the volume to the correct value.
Using a pi 3b+ with Allo Boss DAC
Thanks,
Andreas
eggshell
Re: RuneAudio+R e4
Postby klassikmann » 30 Jul 2020, 20:10
klassikmann
Re: RuneAudio+R e4
Postby R101 » 30 Jul 2020, 21:24
@rern
After updating, I have no Webradio stations. I tried importing with the addon, but still nothing. When I click on the library icon, I just get the Add Webradio form.
Edit: MPD scan does not complete either.
Re: RuneAudio+R e4
Postby belgarath0815 » 30 Jul 2020, 21:59
0730 update fixed my browse by folder problem
THX!
belgarath0815
Re: RuneAudio+R e4
Postby cmh714 » 30 Jul 2020, 22:30
Lost my Web Radios and when I click on my Hard Drive, instead of my folders/files coming up I get the Sources page, which shows I am mounted....
