RuneAudio+R e4
Re: RuneAudio+R e4
Postby vaughan » 30 Jun 2020, 10:50
vaughan
Re: RuneAudio+R e4
Postby R101 » 30 Jun 2020, 12:08
Thanks rern. The interface also seems faster now.
The only problem I have seen is the disabled volume control randomly appearing on the playback page. Refreshing the browser gets rid of it, but I can't work out what makes it appear, or which setting hides it. It is greyed out in the playback page settings, not blank like the other tick-boxes.
Would it be possible to have all the library icons the same colour? The Webradio one looks odd alongside the coloured bookmark icons.
Re: RuneAudio+R e4
Postby rern » 30 Jun 2020, 15:00
Re: RuneAudio+R e4
Postby Garrido33 » 30 Jun 2020, 15:18
Hi Rern,
The problem with the settings is solved with the new image files.
Thanks,
Garrido33
Garrido33
Re: RuneAudio+R e4
Postby ceejayemm » 30 Jun 2020, 17:24
Rern
There must be something else causing the backup problem. I emptied the coverarts folder before trying to make a backup and it still failed. I have attached the resulting backup file for you to see.
Chris
backup (2).zip
(274 Bytes) Downloaded 473 times
ceejayemm
Re: RuneAudio+R e4
Postby Reliang268 » 01 Jul 2020, 03:27
Smooth installation good job. I have 2 issue:
1. When playback DSD dsf file, touching the volume will output a sort of white noise and no more music. No more DSD file can be play. At the MPD menu the volume control also cannot touch as it will cause DDS cannot play (no music output only noise)
2. Wifi country is 00 which is why the 5G wifi cannot be found. How to set the default wifi country? Temporary I use "iw reg set SG" to set the wifi country. Thanks KM
Reliang268
Re: RuneAudio+R e4
Postby rern » 01 Jul 2020, 04:43
Re: RuneAudio+R e4
Postby R101 » 01 Jul 2020, 11:59
Re: RuneAudio+R e4
Postby rern » 01 Jul 2020, 12:28
Re: RuneAudio+R e4
Postby R101 » 01 Jul 2020, 12:57
Users browsing this forum: Baidu [Spider] and 21 guests
