RuneAudio+R e4
Re: RuneAudio+R e4
Postby vaughan » 01 Jul 2020, 17:34
vaughan
Re: RuneAudio+R e4
Postby vaughan » 01 Jul 2020, 17:41
vaughan
Re: RuneAudio+R e4
Postby Sonic » 01 Jul 2020, 21:35
Sorry if I’m missing something – I’ve tried and tried to find a way round this. But, unfortunately, it appears that the scroll bars have been removed from the Rpi GUI, and e3/e4 have seemingly become unusable with a large album collection without a touch screen.
The arrow keyboard shortcuts in the library are broken (although they work in the playlist). Without these it’s actually impossible to access many of my albums because the only way to navigate through the lists is via the ‘jump to a letter’ bar. If you have more artists or album titles starting with the selected letter than can fit on a single page there is no other way to scroll through the entries. The Date page is a non-starter as it has no active ‘jump to’ bar to start with (By the way, thanks for adding that Rern).
When I say the arrow keyboard shortcuts are broken, what they are actually doing is is somewhat weird. As an example: regardless of where your current position is within a list, if you press the downward arrow, in say the Album Artist list, it first jumps back to the beginning of the list and highlights the very first entry. The next down arrow key press will jump to the next artist entry and open its album submenu and highlight the first album, and the next down arrow key press will jump down to the next album entry and open the track list. This happens in both the Rpi GUI and a remote browser (Firefox in my case).
Plus, and I think this has already been reported, attempting to open the ‘System’ page simply results in the busy screen endlessly flashing until a forced reboot.
Sonic
RPi3B+ > Allo DigiOne Signature > Audiolab M-DAC
RPi3B+ > HiFiBerry Digi+ Pro > Cambridge Audio DACMagic+
Sonic
Re: RuneAudio+R e4
Postby cmh714 » 01 Jul 2020, 21:58
@rern, just re-flashed as you stated a post or two back.....the restore didnt seem to fully restore everything....it did not set my TZ correctly as it has in the past.
Also, bigger was that it did not restore my Playlists....anyway to recover that?
****EDIT -- NM rern, the Playlists just took some time to re-populate into the UI.
Re: RuneAudio+R e4
Postby PiPPiP » 02 Jul 2020, 05:03
Am also having the flashing RA page trying to access systems settings both on touch screen and web interface (am still on e3, but will upgrade to e4 presently).
On that matter, is there a simple list of command line instructions to do the upgrade so to avoid back up issues and or reflashing SD card?
regards,
P
PiPPiP
Re: RuneAudio+R e4
Postby Russ » 02 Jul 2020, 11:01
Russ
Re: RuneAudio+R e4
Postby rern » 02 Jul 2020, 12:32
Re: RuneAudio+R e4
Postby Sonic » 02 Jul 2020, 16:06
Sonic
Re: RuneAudio+R e4
Postby Sonic » 02 Jul 2020, 21:39
Sonic
Re: RuneAudio+R e4
Postby rern » 03 Jul 2020, 11:10
Update 20200703
- Fix AirPlay bug
- Fix backup failed when there're special characters in filenames
- Fix System page inaccessible in some situations
- Improve keyboard shortcuts
- Add regulatory domain option for Wi-Fi
