RuneAudio+R e4
Re: RuneAudio+R e4
Postby Russ » 03 Jul 2020, 11:29
Russ
Re: RuneAudio+R e4
Postby R101 » 03 Jul 2020, 11:39
@rern
After the latest update and a reboot, the playback display menu does not work. If I disable the volume control, the cover art is enabled. If I disable the cover art, the volume control is enabled.
Re: RuneAudio+R e4
Postby rern » 03 Jul 2020, 12:38
Re: RuneAudio+R e4
Postby Reliang268 » 06 Jul 2020, 03:10
Hi I am new to this Runeaudio or raspberry pi. Can anyone help tp explain how to use the function Access Point (AP). I am able to connect to this wifi hotspot but what to do next?
I think it is a good ideal to have the rpi with AP when there is no Ethernet hard wire connection available (example at hotel room) to assist in wifi setup the rpi.
Hardware: Rpi 4b 8gb
Software: RuneAudio+Re4 (latest fw)
USB audio dac: Topping D10
Thanks,
Reliang268
Re: RuneAudio+R e4
Postby cmh714 » 06 Jul 2020, 05:08
Once connected to the AP, you can then use a Browser and open the IP so you can see and use the UI.
You can also use the app https://play.google.com/store/apps/deta ... .runeaudio
Re: RuneAudio+R e4
Postby Russ » 06 Jul 2020, 07:06
Russ
Re: RuneAudio+R e4
Postby Reliang268 » 06 Jul 2020, 11:55
Reliang268
Re: RuneAudio+R e4
Reliang268
Re: RuneAudio+R e4
Postby Jules382 » 06 Jul 2020, 13:25
Hi Rern.
Firstly many thanks for all of your work on this excellent player. I really love it. Very much appreciated.
I am unable to enable Bit Perfect playback, when I try I get the pop up and the toggle moves across and goes blue, a second later the toggle moves back across and goes grey again. I have tried various settings but cannot get it to work. Could you help please.
System is:
Raspberry Pi 3 Model B Rev 1.2
Rune Audio E4 20200703
Arcam irDAC II
Connecting to LAN using WiFi
Are there any plans to enable LASTFM scrobbling in the future?
Many thanks again.
Jules
Jules382
Re: RuneAudio+R e4
Postby rern » 07 Jul 2020, 15:06
