RuneAudio+R e4
Re: RuneAudio+R e4
Postby cycl157 » 21 Jul 2020, 17:09
I seem to have lost the ability to play tracks in a playlist in random order. The shuffle button will show that it's on, but not actually shuffle, and if I refresh the page (from another computer) after selecting the button to turn off it still shows on.
I did update to 20200720. I had not noticed this before. I did reboot, just in case that might help, but no difference.
cycl157
Re: RuneAudio+R e4
Postby ceejayemm » 21 Jul 2020, 17:47
Rern
Looking through the dmesg logs, I see there are failures like:
[ 25.841380] snd-rpi-simple soc:sound: ASoC: failed to init link MerusAmp: -517
and it seems as though Volumio are also having similar problems with the Merus Amp HAT and the latest kernel drivers, see:
https://github.com/volumio/Volumio2/issues/1990
Might give you some clues ? I have attached a dmesg log file for you to see.
Chris
dmesg.zip
(12.79 KiB) Downloaded 491 times
ceejayemm
Re: RuneAudio+R e4
Postby eggshell » 21 Jul 2020, 21:38
Hi rern,
What happened to the GPIO Add-on? Just ordered 2 relays :)
Andreas
eggshell
Re: RuneAudio+R e4
Postby rern » 22 Jul 2020, 05:09
Re: RuneAudio+R e4
Postby rern » 22 Jul 2020, 07:03
Re: RuneAudio+R e4
Postby steffe » 22 Jul 2020, 08:12
steffe
Re: RuneAudio+R e4
Postby ceejayemm » 22 Jul 2020, 10:35
Rern
Thanks for the very fast response to my problem. I have downloaded and flashed the SD card with the new Pi Zero version form Post 1 and this seems to have cured the problems I was having with the Merus Amp. I have completed the setup, updated my library and the PI/Merus is playing quite happliy whilst writing this note.
There is however one small, very minor, issue. If I try to update the CoverArt in the Library I get:
wget -q
chmod 755
! Install file download failed.
Please try again.
This isn't a major issue for me so long as the music plays - which it continues to do.
Many thanks again, keep up your great work.
Chris
ceejayemm
Re: RuneAudio+R e4
Postby R101 » 22 Jul 2020, 21:35
@rern
I have just tried a fresh install, using the wifi profile generator for fixed IP and hidden SSID, and it worked perfectly.
The only bug to report is that the Webradio Change Cover Art option does not work. The new logo disappears from the Library entry and does not appear in the playback page.
Re: RuneAudio+R e4
Postby ceejayemm » 23 Jul 2020, 09:19
@R101
I don't have your problem with changing Web Radio coverarts. The radio stations and logos I setup yesterday on my new PI Zero W have remianed in place when I started the PI this morning.
@Rern
I do however have a problem with the Addons page. When the pI started this morning the Cog Wheel in the main menu had a red dot on it (to indicate new addons ?) so I went to the Addons page but it only displayed the little bar graph of the free disk space and nothing else.
Chris
ceejayemm
Re: RuneAudio+R e4
Postby klassikmann » 23 Jul 2020, 09:37
klassikmann
