RuneAudio+R e4
RuneAudio+R e4
Postby rern » 23 Jun 2020, 08:07
Re: RuneAudio+R e4
Postby cmh714 » 23 Jun 2020, 17:09
Seems pretty good so far.....I am having some minor issues with some of my web radios, but dont think its Rune.....
Thanks rern!
Re: RuneAudio+R e4
Postby ceejayemm » 23 Jun 2020, 17:27
Rern
Thanks for this new version which I downloaded earlier today and did the following:
1. Backup existing RA-Re3 using System Backup
2. Flash a new SD card with RA-Re4 and booted PI3B with this image
3. Restored backup file saved in (1) above.
4. Reboot (not sure if I needed to do this) but I did anyway
All seems OK except:
a) System came up on final boot using 'Device - On-board Headphones' by default, easily switched back to IQAudIODAC, all other settings seem to have been restored correctly.
b) like CMH714, some of my web radios are not working (eg http://minimserver:9790/minimstreamer/*/D_R2 - BBC national radio via Minimserver setup - I know the previous discussions about using this but it works for me) but http://str1.sad.ukrd.com:80/eagle is working.
One other really minor point - would it be possible to get a version of the slideshow you published are part of the e4 release notification with the image change rate slowed down or with a click to move (forwards/backwards) added so that I can more easily see all the features of this release ?
Chris
ceejayemm
Re: RuneAudio+R e4
Postby ceejayemm » 23 Jun 2020, 17:36
Rern
Should have said http://minimserver:9790/minimstreamer/*/D_R2 plays Ok in RA-e3 and VLC and direct url of direct URL for same station (http://a.files.bbci.co.uk/media/live/ma ... o_two.m3u8) also plays OK.
Chris
ceejayemm
Re: RuneAudio+R e4
Postby Russ » 25 Jun 2020, 07:32
Russ
Re: RuneAudio+R e4
Postby cycl157 » 25 Jun 2020, 15:30
Is there a way to set wireless profile information or the backup file on the image before trying to boot from it? I run rune over wifi and without a screen -- would be nice if I could just swap the card without having to move the pi to somewhere with lan and/or keyboard and display.
I am loving all of the updates -- THANK YOU!!!!
cycl157
Re: RuneAudio+R e4
Postby rern » 25 Jun 2020, 15:58
Re: RuneAudio+R e4
Postby rern » 26 Jun 2020, 04:38
Re: RuneAudio+R e4
Postby ceejayemm » 26 Jun 2020, 09:08
Rern
Thanks for the information about the slideshow, that makes life a lot simpler.
I have also resolved the issue with my 'faulty' web radios. In Re3 I was able to use the url http://minimserver:9790/minimstreamer/*/D_R2 however in Re4 I need to use http://minimserver.lan:9790/minimstreamer/*/D_R2 or the IP number (http://192.168.86.70:9790/minimstreamer/*/D_R2) as for some reason Re4 no longer resolves just the server name ('minimserver') in a web radio url. This strange because in my Sources screen I CAN set up my NFS Device server name to be 'CMHomeNAS1' which does resolve to 'cmhomenas1.lan' or 192.168.86.250 correctly. As you can see both minimserver and cmhomenas1 are on the same network and domain.
Shouldn't there be consistency as to how server names are resolved ?
Chris
ceejayemm
Re: RuneAudio+R e4
Postby ceejayemm » 26 Jun 2020, 16:13
Rern
It appears that my Re4 installation is trying to resolve network addresses using a DNS server at 192.168.86.1 but in fact my DNS server is actually at 192.168.86.10. How can I correct the DNS Server settings to point to the correct DNS server.
Chris
ceejayemm
