RuneAudio+R e5
Re: RuneAudio+R e5
Postby rern » 25 Sep 2020, 03:12
Re: RuneAudio+R e5
Postby matt » 25 Sep 2020, 05:02
any idea how I can get the missing folder to show up? The albums appear under the albums tab but when I click on them it says no data in this location.
The band name is also listed in the artists tab.
matt
Re: RuneAudio+R e5
Postby AnaximanderThales » 25 Sep 2020, 22:50
I'm having some issues finding out about enabling HDMI support. I see several people mention having it, but I'm not seeing where and how it's actually configured.
Based on poking around, it seems I'll need to add something to my /boot/config.txt file. The only item I've found that specifically mentions a file is from RA-beta0.3. It's one line in the /boot/config.txt file. Also, since it's linux based and using alsa, I would imagine I need to configure an HDMI output in the /etc/alsa/20-bluealsa.conf. I'm not confident on the alsa config, as that seems to pertain to bluetooth, but it's what I would have edited prior to moving to pulseaudio on my linux boxes.
It also appears that I may need to add a line or two in my /etc/mpd.conf file as well.
That said -- what am I adding. Raspberry pi has quite a lot of HDMI settings, but I'm not sure if I need to add all, add some, or just add one line. I've dabble in MPD a while back, but I was using pulseaudio during that time, so I have no alsa config information for MPD.
Where do I find what to add and to which files I add them to.
Thanks,
Anaximander Thales.
AnaximanderThales
Re: RuneAudio+R e5
Postby rern » 27 Sep 2020, 07:25
Re: RuneAudio+R e5
Postby rern » 27 Sep 2020, 07:36
Re: RuneAudio+R e5
Postby ceejayemm » 27 Sep 2020, 09:17
Hi @rern
I updated to 20200927 this morning and can confirm the spurious GPIO icon on the playback page has gone.
During the update I noticed a few 'databases' were being updated and once the update completed (with no apparent errors) I could see that the icon set used on the Library main page has changed. You used to provide a list of items that changed on such an update but recently this has been simply the generic 'Bug Fixes'. Can we get back to knowing what has actually changed with each release, if only to know what to look out / for / test if necessary ? Have I 'noticed' all the changes in this release ?
Thanks again for your great efforts.
Chris
ceejayemm
Re: RuneAudio+R e5
Postby AnaximanderThales » 27 Sep 2020, 13:28
AnaximanderThales
Re: RuneAudio+R e5
Postby ceejayemm » 27 Sep 2020, 14:19
@Anaximander
Try rebooting the PI with your HDMI device plugged in so that it gets recognised at boot time. The HDMI device should then be available to select under the MPD settings along with the headphone settings.
Chris
ceejayemm
Re: RuneAudio+R e5
Postby AnaximanderThales » 27 Sep 2020, 21:36
AnaximanderThales
Re: RuneAudio+R e5
Postby AnaximanderThales » 28 Sep 2020, 00:14
Okay, Chris. Here's wherei am at now.
Tried a new download, burned the image and plugged everything up. Booted up just fine. Applied the update. Rotated the screen, and assigned the ip. I still do not have HDMI sound, not do I have a way to select HDMI.
Checking in the devices list, I have card0 and device0 set with headphones, and 8 unassigned sub devices.
Hardware mixer is only headphones.
AnaximanderThales
