RuneAudio+R e5
Re: RuneAudio+R e5
Postby holzboa » 28 Sep 2020, 13:56
holzboa
Re: RuneAudio+R e5
Postby Biedronek » 29 Sep 2020, 16:14
I have just switched from official releases to e5 and experienced a few issues. I wonder if these are known one something is wrong with my setup:
1.a dd'ed image to 8GB sd card and after boot did not find option to extent the fs (did it manually via cli),
1.b the auto-upgrade did not start once I resized partition, but frankly speaking I am not really sure if I rebooted afterwards. Manual update worked flawlessly,
2. cannot mount NFS through UI - it said it was mounted but that not really happened. Eventually did it form cli and things work fine,
3. controls (progress bar at least) do not get updated unless they are hoovered (Firefox). In similar way the number of seconds displayed refers to focus time rather than actual song elapsed time (progress bar is OK),
4. on mobile Safari there are no navigation tabs on top, and at the bottom they work but are not visible.
I used a binary image, not building from scratch.
And a quick question - what is the backend for GPIO management?
Biedronek
Re: RuneAudio+R e5
Postby rern » 30 Sep 2020, 14:47
Re: RuneAudio+R e5
Postby Biedronek » 30 Sep 2020, 22:08
Thank you!
I am sorry for 4th, I once noticed that and then just forgot entirely.
As for 3 - I will see if I can reproduce, for now cannot observe the time being out of sync with progress bar either. That's good :-)
Regarding 2 both your and my commands work fine when typed in terminal, just from UI it does not work. Both sides are nfsv4. The blinking label says "Done" but mount command does not show new resource. Anyway, if no one else experiences this then it might be some local issue.
Biedronek
Re: RuneAudio+R e5
Postby AnaximanderThales » 01 Oct 2020, 21:13
AnaximanderThales
Re: RuneAudio+R e5
Postby jsouza » 02 Oct 2020, 20:10
I'm running the latest available +R e5 release (20200927) and once again the library builder is giving up the ghost when I rebuild the MPD database. My NAS shares should have about 35,000 FLAC files but the MPD database in RuneAudio is showing only about 13,000. I saw an earlier response where rern said "It might be some filenames or tags have non-utf8 characters." My question is, is there any way to know which file(s) are causing issues when building the database? If I knew which files were problematic then I could easily go fix the tags, but as it is now I have no way of knowing. Thanks.
-Joe
jsouza
Re: RuneAudio+R e5
Postby rern » 03 Oct 2020, 06:54
Re: RuneAudio+R e5
Postby R101 » 04 Oct 2020, 19:47
I have noticed that the cover art is out of step with the track information when listening to Paradise Radio. Anyone else have this?
Re: RuneAudio+R e5
Postby rawdevice » 05 Oct 2020, 10:56
rawdevice
Re: RuneAudio+R e5
Postby R101 » 05 Oct 2020, 12:00
Users browsing this forum: No registered users and 34 guests
