RuneAudio+R e5
RuneAudio+R e5
Postby rern » 24 Aug 2020, 07:50
Re: RuneAudio+R e5
Postby RobP » 24 Aug 2020, 09:53
OO Thank you. I'll try it right now and get back.
Edit:
Working now. I've got a fairly simple set-up: RPi4 connected to wireless AP via ethernet cable. HDMI cable to AV amplifier. Audio files on hard-drive connected via USB but seems to work ok for me. Finds all the files, plays them etc.
RobP
Re: RuneAudio+R e5
Postby hermano » 24 Aug 2020, 10:58
Thanks rern,
Running now, but same for me as +Re4, the date function not working. Click on a year and it just hangs (flashing RuneAudio). using Pi4 and RuneAudio+R e5
hermano
Re: RuneAudio+R e5
Postby R101 » 24 Aug 2020, 12:09
Hi rern,
I am not getting any embedded cover art from the radio streams.
The Webradio change cover art function converts a png image to a jpg thumbnail, but leaves the playback image as a png, which does not display.
Edit:
Also, NAS does not mount automatically. (Edit:) If the share name has a space in it, so not a problem.
Re: RuneAudio+R e5
Postby cmh714 » 24 Aug 2020, 15:48
Restored my previous settings and now a bit messed up.....I cannot get to any of the Settings pages, clicking the Gear icon does nothing atm....
****EDIT: OK, so I added a Radio to the playlist and now the Settings menu does Open properly!
***CRAP: now after another reboot I have absolutely no controls on the UI....just the Rune Audio logo....argh
Re: RuneAudio+R e5
Postby cotriumph » 24 Aug 2020, 17:54
Thanks for the e5 release! Spotify now works for me (would not connect in e4).
I also see you have added Bluetooth back to the system settings, and I've activated this, but I'm not seeing any runeaudio bluetooth device on my phone or computer. Is there a trick to get this initialized and in pairing mode?
Running latest e5 for Pi4.
Update, whenever I go into MPD settings (even when not changing anything), then closing, i get the blank screen with RuneAudio logo. Need to reboot Pi4 to get back to normal.
Cheers!
cotriumph
Re: RuneAudio+R e5
Postby AndyF » 24 Aug 2020, 19:47
@cmh714
Try to restart mpd and mpdidle service via ssh and systemctl. If you get UI back, try to reconfigure your soundcard.
Disablng i2s + reboot / re-set i2s + reboot worked on my system.
regards, Andy
AndyF
Re: RuneAudio+R e5
Postby cmh714 » 24 Aug 2020, 20:52
Thanks Andy! Since my setup is pretty straightforward and I have been at this for so long now I can just start over and be up and running in short order....HOWEVER, starting clean, I am having all sorts of odd issues....First the UI is acting weird, again the Gear icon in the "Circle" is broken but I can use the one at the bottom....I imported my webradios, then created a Playlist and then I had absolutely no control over the UI again....all I have is the Rune Audio logo, cant swipe, nothing to click on.....
Re: RuneAudio+R e5
Postby cotriumph » 24 Aug 2020, 22:27
I think part of my 'blank screen with rune logo' is related to airplay and/or spotify. I was just air-playing (as i can't get Bluetooth to work) from my phone, and noticed the web interface had changed to the blank+logo view. I paused the airplay stream, and it instantly came back. On starting playing again, it showed the coverart view that allows me to get to configuration etc.
As soon as I go back into configuration though and exit though, back the blank screen.
cotriumph
Re: RuneAudio+R e5
Postby RolandBlaze » 25 Aug 2020, 12:07
@Rern
Can't mount on NAS on new build, using same credentials/details that have worked previously.
Tried restore config on fresh install
Tried restore config fresh install - and latest update (today)
Tried Fresh install - no restore
Tried fresh install with todays update
After this all fails i then can no longer access settings and sources.. just sits there
Also disable volume control for DAC and noted the volume was "down low" even though setings should be of, swaped sdcard to previous build tha also has volume off and noted the volume went back 100 with volume settings off.
no luck. This appears to be same issue as with early +R e4
Thanks.
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Users browsing this forum: Bing [Bot] and 11 guests
