RuneAudio+R e6
Re: RuneAudio+R e6
Postby rern » 21 Oct 2020, 03:27
Re: RuneAudio+R e6
Postby Ears of Tin » 21 Oct 2020, 04:48
Thanks Rern! You probably won't be surprised that DAC selection is now sticking. It appeared to fix after the first set of cat commands i.e. without rebooting. Obviously due to the quantum effects of observing the system per Heisenberg.
Before reboot:
root@RuneAudio:~ # cat /srv/http/data/system/audio-aplayname
hifiberry-dacplus
root@RuneAudio:~ # cat /srv/http/data/system/audio-output
HiFiBerry DAC+
root@RuneAudio:~ # cat /boot/config.txt
force_turbo=1
gpu_mem=32
initramfs initramfs-linux.img followkernel
max_usb_current=1
disable_splash=1
disable_overscan=1
dtparam=audio=off
dtparam=i2s=on
dtoverlay=hifiberry-dacplus
After reboot:
hifiberry-dacplus
HiFiBerry DAC+
force_turbo=1
gpu_mem=32
max_usb_current=1
disable_splash=1
disable_overscan=1
dtparam=audio=off
dtparam=i2s=on
Ears of Tin
Re: RuneAudio+R e6
Postby RolandBlaze » 21 Oct 2020, 16:53
@Rern
Thanks for the latest R6 Version another level up :) .
I have a few questions please...
How do you un-bookmark an album?
How do I populate/update the "Album" part of the library.. I have thousands of albums with coverart.. only 4 show in album and 1 of them shows the cover art but when you click them they display the cover in album playlist view?
Thanks as always,
Roland.
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Re: RuneAudio+R e6
Postby ceejayemm » 21 Oct 2020, 18:36
RolandBlaze
I am not sure what you mean by 'un-bookmark and album' ? Do you mean remove it from the Playlist page ? If so, select the items you want to remove and click the minus icon on the top menu bar of the Playlist page and select 'All' from the resulting dialogue item. To remove a single track, left click the item to remove and click 'Remove'.
Have you populated the RA database via the MPD submenu (the square icon with surrounding arrows to the right of the MPD menu item), using the 'Rebuild Entire Database' time ? What type of audio files are you using and have you enabled the 'FFmpeg Decoder' option on the MPD main page ?
Chris
ceejayemm
Re: RuneAudio+R e6
Postby RolandBlaze » 21 Oct 2020, 19:26
Chris,
Thanks for trying to assist. Nope, I mean un-bookmark an album. Try selecting an album in your library and choosing bookmark, then go to your library and it will appear there. To me it appears there is no obvious way to remove once done.
I use mainly flac and mp3. Yup to FFmpeg Decoder. I don't have an issue with any of my music (any formats) or covers appearing elsewhere in rune besides "Albums" in the Library.
Roland.
RolandBlaze
Re: RuneAudio+R e6
Postby R101 » 21 Oct 2020, 20:18
Roland,
Do a long press on the bookmark icon. You should get options to delete or edit it.
Re: RuneAudio+R e6
Postby maxsubs » 21 Oct 2020, 20:29
great work! any way to install it in berryboot? thanks!
maxsubs
Re: RuneAudio+R e6
Postby ceejayemm » 21 Oct 2020, 20:31
RolandBlaze
Yes, can now confirm that R101's method for deleting book marks does indeed work.
I seem to remember having a similar problem with the Album entries in the past and, again, Rern had to 'do' something to help me out. Just out of interest do you get all (some ?) albums listed in the Library but with the RuneAudio logo artwork instead of the actual album artwork, if this is the case try running the artwork updater - by long pressing the icon to the right of the word 'ALBUM' at the top of the Albums page. Did you run the database update I mentioned earlier and let if finish (not wanting to tell grandmothers how to suck eggs :-) )?
Out of other ideas now though.
Chris
ceejayemm
Re: RuneAudio+R e6
Postby Ears of Tin » 21 Oct 2020, 23:33
I've been parallel testing on Pi3B and Pi4. Both are working very well. One curiosity is that the Update addon no longer appears on the Pi4 installation.
Had a few difficulties with the Pi3B (thanks Rern for your assistance). I was suspicious at how easily my DAC problem resolved. Additionally, I couldn't mount a network drive even by editing the fstab file. Without similar problems on the Pi4 I began to suspect my 3B image was corrupt. Downloaded again, reimaged and everything worked.
Ears of Tin
Re: RuneAudio+R e6
Postby ceejayemm » 22 Oct 2020, 08:43
Ears of Tin
I had the missing Addons problem during testing on Re6 on my RPI Zero W. Rern suggested the following to fix it (which it did):
echo 20201014 > /srv/http/data/addons/rre6
You may then need to run the Addons to pick up the latest changes.
Chris
ceejayemm
