RuneAudio+R e6
Re: RuneAudio+R e6
Postby pixel » 06 Nov 2020, 20:36
I'm probably doing something wrong.
1 step format sd card
2 step Win32 Disk Imager --- RuneAudio R_e6-RPi2-3.img.xz to sd card
3 insert the sd card into the Raspberry
It's OK?
pixel
Re: RuneAudio+R e6
Postby cycl157 » 06 Nov 2020, 20:50
cycl157
Re: RuneAudio+R e6
Postby pixel » 06 Nov 2020, 21:20
Wifi does not work. I can not join. I enter my name and password, but it does not connect.
clean new installation
pixel
Re: RuneAudio+R e6
Postby ceejayemm » 06 Nov 2020, 21:31
@Pixel
Why did you junk your original installation, did you not see my post as in:
runeaudio-r-e6-t7141-100.html#p30532
Now that you have reformatted your card, have you followed the instructions in the first post of this thread you were pointed to and if so how far have you got and what errors are you seeing ? If wifi access is actually your problem have you created a file called 'wifi' (with no extension) in the '/boot' folder with the your connection details as shown in the 'wifi0' template file ?
Chris
ceejayemm
Re: RuneAudio+R e6
Postby pixel » 06 Nov 2020, 21:55
i am installing runeaudio for the first time. It has never worked properly for me. What should a Wifi file look like? I never had it.
pixel
Re: RuneAudio+R e6
Postby cycl157 » 06 Nov 2020, 21:59
cycl157
Re: RuneAudio+R e6
Postby ceejayemm » 07 Nov 2020, 11:18
@Rern
Thanks for update 20201107 which does seem to fix the Mouse Pointers issue on a touch screen. However running the update from the touchsreen still does create/update the rr6 file at the end of the update process.
Before applying the update (from the touchscreen):
root@runeaudio+R e6:/srv/http/data/addons # ls -lrt
total 16
-rw-r--r-- 1 root root 9 Nov 6 14:18 rre6
-rw-r--r-- 1 http http 4758 Nov 7 10:08 addons-list.json
-rw-r--r-- 1 http http 1 Nov 7 10:08 update
After the update:
total 8
I then had to reapply the update from my Windows 10 browser which gave:
Before update:
total 12
-rw-r--r-- 1 http http 4758 Nov 7 10:11 addons-list.json
-rw-r--r-- 1 http http 1 Nov 7 10:11 update
After Update:
total 12
-rw-r--r-- 1 root root 9 Nov 7 10:11 rre6
As you can see on this update the rr6 file is created as normal.
Regards.
Chris
ceejayemm
Re: RuneAudio+R e6
Postby rern » 07 Nov 2020, 12:43
Re: RuneAudio+R e6
Postby Alien8 » 07 Nov 2020, 12:51
Rern
Latest 2 updates have a missing icon, in sources page, the network drive icon is missing.
Alien8
Alien8
Re: RuneAudio+R e6
Postby bnilsson » 07 Nov 2020, 17:19
Thanks for the update of UPnP, nice icon.
However, the name is a generic "RuneAudio", not the set system name.
This might cause a problem if you have more than one UPnP device (like I have).
But functionally it works fine now, good work.
bnilsson
