RuneAudio+R e6
RuneAudio+R e6 and Access point
Postby cedefe » 18 Nov 2020, 21:18
I would like to use RuneAudio+Re6 without any network access and I try to activate the Access point "RuneAudio" function but I did not succeed.
The access point does not always appear in the list of accessible networks of the client machine.
When it finally appears, after several restarts of RueAudio, it does not stay there for long and I had to hurry to grab the wifi key:" RuneAudio". Finally, without knowing why, I managed to connect the client machine to the "RuneAudio" access point. I specify that my initial connection was made with an RJ45 Ethernet link. to be able to enter parameters.
I got stuck at this point because it was impossible for me to connect neither with the IP address "http://192.168.5.1", nor by "http: // RuneAudio /", except once, this which I more managed to reproduce.
Of course, I have several times left with a new download and a blank configuration, without success. I use a Raspberry Pi 3 B + and a HifiBerry Digi Pro card on the GPIO connector.
Did you encounter this problem on this version of RuneAudio? Did you succeed ?
RPI 3B+ and HifiBerry Digi Pro and RuneAudio+R e6
cedefe
Re: RuneAudio+R e6
Postby G0MJW » 18 Nov 2020, 21:40
I had the same problem earlier, where were the playlists. Sorting it was easy enough I saved a playlist with a name and used the find command. Let's say the playlist is called Mix
find / -name "Mix"
ought to do the job.
RuneAudio:~ # find / -name "Mix"
/srv/http/data/playlists/Mix
Mike
G0MJW
Re: RuneAudio+R e6
Postby haddock » 21 Nov 2020, 13:29
I'm trying to use RuneAudio+R e6 on a Rpi 3B+ with an Allo Piano 2.1 dac. Not all that easy.
First thing i did was updating RuneAudio. No problem, After that Selecting the Piano 2.1 dac and rebooting went smoothly. Music files were found on an inserted USB stick. But no sound coming from the dac. Opening the mpd tab is not possible. RuneAudio displays the flashing logo.
Unselecting the piano 2.1 dac is also possible. RuneAudio appears to be running correctly.
The dac is ok, as it works with the fork Volumio, but I prefer RuneAudio (running older version for years now).
Any suggestions how to proceed?
Rpi 3B+, Allo Piano 2.1, RuneAudio+R e6
haddock
Re: RuneAudio+R e6
Postby bink » 21 Nov 2020, 14:22
bink
Re: RuneAudio+R e6
Postby klassikmann » 21 Nov 2020, 14:26
Update R+Re6 20201121
Update successful (image file 20201108, boot, update, restore backup).
Up to now one minor issue (but could be my fault): Using Bluetooth as sender not possible, sink found but no connection.
klassikmann
klassikmann
Re: RuneAudio+R e6
Postby rern » 21 Nov 2020, 14:33
@haddock and @bink,
Please try the updated image files from the first post.
- RPi 4, 3, and 2: kernel 5.4.77
- RPi 1 and Zero: kernel 5.4.72 (5.4.77 has some issues with onboard audio.)
By the way, anyone with a character LCD, please try them as well. (System > GPIO Devices)
Re: RuneAudio+R e6
Postby klassikmann » 21 Nov 2020, 14:44
klassikmann
Re: RuneAudio+R e6
Postby rern » 21 Nov 2020, 15:00
@klassikmann,
The updated image files. Still hot right from the oven.
Re: RuneAudio+R e6
Postby haddock » 21 Nov 2020, 15:06
haddock
Re: RuneAudio+R e6
Postby ceejayemm » 21 Nov 2020, 16:45
@Rern
Just updated Pi3B+ to RE6 20201121 (from 20201108) but kernel on system page and via uname -a still reports 5.4.70-1-ARCH. Rebooted, still the same:
uname -a
Linux runeaudio 5.4.70-1-ARCH #1 SMP PREEMPT Wed Oct 7 15:34:50 UTC 2020 armv7l GNU/Linux
Chris
ceejayemm
