RuneAudio+R e6
Re: RuneAudio+R e6
Postby rern » 21 Nov 2020, 16:58
Kernel 5.4.77
- Available in today's updated image files, not by Addons update.
- No needs for any current R+R e6 to reflash the SD cards unless for the character LCD feature or driver issues.
- Manually update with pacman -Syu is OK except RPi 1 and Zero that need onboard audio.
Re: RuneAudio+R e6
Postby ceejayemm » 21 Nov 2020, 17:02
@Rern
Understood, thanks for the explanation.
Chris
ceejayemm
Re: RuneAudio+R e6
Postby bink » 21 Nov 2020, 17:26
bink
Re: RuneAudio+R e6
Postby R101 » 21 Nov 2020, 17:45
Hi rern,
Since the 20201121 update my webradio station names in the library list are being overwritten by the artist last played.
Re: RuneAudio+R e6
Postby Alien8 » 21 Nov 2020, 17:51
Alien8
Re: RuneAudio+R e6
Postby klassikmann » 21 Nov 2020, 21:50
klassikmann
Re: RuneAudio+R e6
Postby ceejayemm » 22 Nov 2020, 10:24
I can confirm R101 / Klassikmann's findings re webradio station names being replaced however it only appears to happen where the station in question provides the necessary information in the link/stream to display current track / artwork etc. So UK BBC stations like Radio2 are apparently NOT affected but GOLD is. I am currently using these links for these stations:
BBC Radio 2
http://as-hls-uk-live.bbcfmt.s.llnwi.ne ... ewind.m3u8
GOLD
http://media-ice.musicradio.com:80/Gold
It seems that the webradio file names in /srv/http/data/webradios are not affect so
BBC Radio2 file name is:
'http:||as-hls-uk-live.bbcfmt.s.llnwi.net|pool_904|live|uk|bbc_radio_two|bbc_radio_two.isml|bbc_radio_two-audio=320000.norewind.m3u8'
and currently contains just the name of the radio station ie 'BBC Radio 2'
whereas the GOLD file name is:
'http:||media-ice.musicradio.com:80|Gold'
and before the problem occurs it also just contains the station name 'Gold', however once the problem occurs it gets changed to contain the track artist/name and the stream info :
Eurythmics
16 bit 44.1 kHz 48 kbit/s
Editing the 'faulty' webradio name entry (back to 'GOLD' in this case) using the GUI results in the file content being changed to:
GOLD
BTW I have only applied the 20201121 update but NOT yet updated the Kernel (as per Rern's note above) and this is occurring on my PI 3B+
Hope this helps
Chris
ceejayemm
Re: RuneAudio+R e6
Postby rern » 22 Nov 2020, 11:15
Update 20201122
- Fix - MPD option settings
- Fix - WebRadio name changed after play
Re: RuneAudio+R e6
Postby klassikmann » 22 Nov 2020, 12:21
klassikmann
Re: RuneAudio+R e6
Postby rern » 22 Nov 2020, 12:27
