RuneAudio+R e6
Re: RuneAudio+R e6
Postby KarelB » 26 Nov 2020, 10:39
Karel
2x RuneAudio @ Raspberry 1 & 2
1x FlightRadar24 @ Raspberry 3
1x RuneAudio+R e6 @ Raspberry 4B + HifiBerry DAC+ PRO - work in progress
3x Kodi @ Raspberry 4B
KarelB
Re: RuneAudio+R e6
Postby rlsten » 26 Nov 2020, 17:47
Updated to Re6 20201122 Kernel 5.4.71-1 with RPi4 and Waveshare Screen attached via DPI (not HDMI or GPIO).
Rotate Screen in landscape now does not work. Have been using this setup for a long time with various versions of Rune Re with no problem until now.
Is there a file I can modify manually to change the rotation?
Thanks!
rlsten
Re: RuneAudio+R e6
Postby losiek68 » 27 Nov 2020, 13:31
I have Raspberry Pi 1 B+ with HiFi Berry DAC and 20x4 LCD display and I am using rune version 0.5. Yesterday I gave a chance to this one and it worked out of the box. I found that this version is slower than rune 0.5. It takes some time to change info after track changed (both web browser and LCD). I know RPi 1 B+ is outdated HW but rune 0.5 with text LCD works like a charm.
I added mappings for polish diacritical letters in hd44780_a00.py. I think it is worth to mention about it.
Could you add scrolling on LCD?
I found that adding source works in old Microsoft Edge (pre Chromium):
but on Chromium based browsers looks like in this
losiek68
Re: RuneAudio+R e6
Postby klassikmann » 27 Nov 2020, 18:41
klassikmann
Re: RuneAudio+R e6
Postby BVLabs » 30 Nov 2020, 09:06
Hello!
All bugs discussed earlier have been fixed. This is great news.
But, now the access point does not work normally - it is impossible to connect, the mobile device does not receive the IP address. Constantly - "obtaining ip address..."
Re6 20201127 • RuneAudio
Raspberry Pi 3 Model B Rev 1.2
BCM2837 • 4 Cortex-A53 @ 1.2GHz • 1GB
Apple Pi DAC
5.4.77-1-ARCH
Boot log:
Nov 30 09:59:33 runeaudio hostapd[309]: Configuration file: /etc/hostapd/hostapd.conf
Nov 30 09:59:33 runeaudio hostapd[309]: wlan0: Could not connect to kernel driver
Nov 30 09:59:33 runeaudio hostapd[309]: Using interface wlan0 with hwaddr b8:27:eb:30:60:94 and ssid "RuneAudio"
Nov 30 09:59:33 runeaudio hostapd[309]: random: Cannot read from /dev/random: Resource temporarily unavailable
Nov 30 09:59:33 runeaudio hostapd[309]: random: Only 0/20 bytes of strong random data available
Nov 30 09:59:33 runeaudio hostapd[309]: random: Not enough entropy pool available for secure operations
Nov 30 09:59:33 runeaudio hostapd[309]: WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
Nov 30 09:59:34 runeaudio dnsmasq[310]: dnsmasq: syntax check OK.
Nov 30 09:59:34 runeaudio systemd-networkd[217]: wlan0: Gained carrier
Nov 30 09:59:34 runeaudio hostapd[309]: wlan0: interface state UNINITIALIZED->ENABLED
Nov 30 09:59:34 runeaudio hostapd[309]: wlan0: AP-ENABLED
Nov 30 09:59:34 runeaudio systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Nov 30 09:59:34 runeaudio systemd[1]: Reached target Network is Online.
Nov 30 09:59:34 runeaudio systemd[1]: Reached target Host and Network Name Lookups.
Nov 30 09:59:34 runeaudio kernel: audit: type=1130 audit(1606723174.124:26): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 30 09:59:34 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 30 09:59:34 runeaudio systemd[1]: Started Shairport Sync - AirPlay Audio Receiver.
Nov 30 09:59:34 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shairport-sync comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 30 09:59:34 runeaudio kernel: audit: type=1130 audit(1606723174.144:27): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shairport-sync comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 30 09:59:34 runeaudio systemd[1]: Started UPnP Renderer front-end to MPD.
Nov 30 09:59:34 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upmpdcli comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 30 09:59:34 runeaudio dnsmasq[315]: started, version 2.82 cachesize 150
Nov 30 09:59:34 runeaudio dnsmasq[315]: compile time options: IPv6 GNU-getopt DBus no-UBus i18n IDN2 DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Nov 30 09:59:34 runeaudio dnsmasq[315]: DBus support enabled: connected to system bus
Nov 30 09:59:34 runeaudio dnsmasq[315]: warning: interface wlan0 does not currently exist
Nov 30 09:59:34 runeaudio dnsmasq-dhcp[315]: DHCP, IP range 192.168.5.2 -- 192.168.5.254, lease time 1d
Nov 30 09:59:34 runeaudio dnsmasq[315]: reading /etc/resolv.conf
Nov 30 09:59:34 runeaudio dnsmasq[315]: using nameserver 217.19.208.19#53
Nov 30 09:59:34 runeaudio dnsmasq[315]: using nameserver 8.8.4.4#53
Nov 30 09:59:34 runeaudio dnsmasq[315]: cleared cache
Nov 30 09:59:34 runeaudio sshd[312]: Server listening on 0.0.0.0 port 22.
Terra-Berry DAC2+
BVLabs
Re: RuneAudio+R e6
Postby R101 » 30 Nov 2020, 12:05
@rern,
There is a small bug on the playlist page.
If the playlist is displayed, when the cursor moves to track 2, it leaves the play icon and elapsed time showing on track 1 until it moves on to track 3. It then leaves the icon on track 3 until it moves to track 5, and so on. Any action which refreshes the page, clears the error.
Re: RuneAudio+R e6
Postby R101 » 30 Nov 2020, 17:37
@rern,
Sorry rern, I think I have found another one. I unplugged and reconnected the USB DAC for the first time since the update, and am now back to having no sound card detected and no sound card entry in mpd.conf.
Re: RuneAudio+R e6
Postby kiko » 01 Dec 2020, 01:00
I have added several of my streaming stations from the DI.FM service.
When I try to play one of them, I get:
Nov 30 15:41 : ffmpeg/lrc: Format lrc detected only with low score of 5, misdetection possible!
Nov 30 15:41 : ffmpeg: No audio stream inside
Nov 30 15:41 : exception: Failed to decode http://listen.jazzradio.com/premium/smo ... c8e262201d
Nov 30 15:41 : player: played "http://listen.jazzradio.com/premium/smoothjazz.pls?listen_key=keygoeshere"
I can take the same URL and play it in VLC.
Any Idea what the issue may be?
RuneAdudio e6 20201127
Raspberry Pi 3 Model B Plus Rev 1.3
kiko
Re: RuneAudio+R e6
Postby cmh714 » 01 Dec 2020, 02:14
Re: RuneAudio+R e6
Postby BVLabs » 02 Dec 2020, 09:41
Hi! In the new update, all the problems I described are fixed. Thank you so much, Rern!
Question: how can I turn off the check for updates? For example, I want to freeze this assembly at this stage.
Maybe this can be done with an option in the section - Features?
Terra-Berry DAC2+
BVLabs
Users browsing this forum: Bing [Bot] and 0 guests
