RuneAudio+R e6
Re: RuneAudio+R e6
Postby Ears of Tin » 22 Oct 2020, 14:32
Hi Chris,
That was easy. Pi4 now updated.
Ears of Tin
Re: RuneAudio+R e6
Postby Russ » 22 Oct 2020, 15:41
Hi Rern,
A question on spotifyd: I note that the info on the UI (great job on the UI, btw) states a sample rate of 48 kHz which was confirmed on my USB DAC display. I presume that this is because of an audio parameter on the RPi as I can change the sample rate back to 44.1 kHz (Spotify native) on my PC (through the USB XMOS Driver.)
How do I tweak Re6 to play Spotify at 44.1 kHz sample rate? Or rather, how do I get Re6 to play Spotify at its native sample rate. I remember, some time back, I changed an audio configuration file (alsa.conf maybe) to achieve this. But it also meant it would play all other sources at 44.1 kHz too - which I did not want. So I ended up with a Larkbox to play Spotify and RPi for radio and music files.
Russ
Re: RuneAudio+R e6
Postby Alien8 » 22 Oct 2020, 17:09
Alien8
Re: RuneAudio+R e6
Postby kiko » 22 Oct 2020, 22:38
MPD is getting partially through scanning the media shares and will end up with:
Oct 22 14:15 : exception: error on client 93: Output buffer is full
Oct 22 14:15 : exception: No such directory
And will not restart the share that has the problem.
My library is not small:
Artists: 34,754
Albums: 12,272
Songs: 183,777
And that's not all, it should be over 250K songs and I have not added the share for the DTS music.
All my music is stored on a Qnap NAS with gigabit Ethernet, Raspberry PI 3 connected over Ethernet not WiFi.
Other that this issue Re6 is great, play back of audio sounds super!
kiko
Re: RuneAudio+R e6
Postby klassikmann » 23 Oct 2020, 12:05
Update R+Re6 20201023
In I described the process to establish a BT connection as a receiver (sink). After today's update the steps are no more necessary. It's now fully automatic!
For completeness I had a look on the sender (source) mode: It's just that simple!
klassikmann
klassikmann
Re: RuneAudio+R e6
Postby Ears of Tin » 23 Oct 2020, 15:49
Re Bluetooth:
Listening to a podcast from my phone now. It's fantastic. Now I can take the Chromecasts off my receivers.
Reboot twice if needed. First time bluetooth was not in discoverable mode.
Ears of Tin
Re: RuneAudio+R e6
Postby maxsubs » 23 Oct 2020, 18:19
has anyone installe this version in berryboot? how? It's the only way I can use it, thanks
maxsubs
Re: RuneAudio+R e6
Postby RolandBlaze » 23 Oct 2020, 19:18
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Re: RuneAudio+R e6
Postby R101 » 23 Oct 2020, 20:30
Hi rern,
I have been having trouble with the backup/restore utility in the system menu, and I think I can see what is going on.
The /etc/netctl/SSID file which is saved in backup.gz is not the current one, but the one which was last restored. If I edit the profile in /etc/netctl, the changed file is not saved in the backup. I think this might be the case for some other files as well.
Re: RuneAudio+R e6
Postby rern » 24 Oct 2020, 14:39
