RuneAudio+R e6
Re: RuneAudio+R e6
Postby s.k. » 02 Dec 2020, 10:24
s.k.
Re: RuneAudio+R e6
Postby Russ » 02 Dec 2020, 11:08
Russ
Re: RuneAudio+R e6
Postby R101 » 02 Dec 2020, 11:44
Re: RuneAudio+R e6
Postby s.k. » 02 Dec 2020, 15:23
Update 20201201
• Rune logo in ssh isn’t displayed correctly
• Doesn’t shows the fourth kernel load in Status
This “Voltage under 4.7V” does not appeared in my “prototype” SD image, but it appears on any clone made from it.
I haven’t notice any audible malfunction because of it.
• Disk capacity is missing (was on top in Addons page)
• A disk expansion addon would be nice
s.k.
Re: RuneAudio+R e6
Postby Alien8 » 02 Dec 2020, 16:07
Most of not all issues are now fixed.
My lcd still won't work with this. After much search I managed to get some characters on the display but nothing meaningful...
As mentioned earlier I have only gpio mode with different pinout.
One issue is but even with that I have no succes.
My pinout is definitely different, rs =8, en =7, r/w =None, d4-d8 =25,24,23,27.
Lcdchar claims only 26 pins support.
With GPIO.BCM I could assign pins directly and as said get a few characters but alas no useful display.
My (heavily modded) dockerized pydPiper script works fine though.(switching back and forth to debug)
A8
Alien8
Re: RuneAudio+R e6
Postby rern » 02 Dec 2020, 16:33
Re: RuneAudio+R e6
Postby R101 » 02 Dec 2020, 18:16
@rern,
After unplugging the USB DAC and reconnecting it, I have to remount my USB memory stick and do a rescan.
Re: RuneAudio+R e6
Postby KarelB » 02 Dec 2020, 19:30
Karel
2x RuneAudio @ Raspberry 1 & 2
1x FlightRadar24 @ Raspberry 3
1x RuneAudio+R e6 @ Raspberry 4B + HifiBerry DAC+ PRO - work in progress
3x Kodi @ Raspberry 4B
KarelB
Re: RuneAudio+R e6
Postby kolmberger » 03 Dec 2020, 11:23
Thanks a lot to the developers for doing such a great work.
May I post my latest issue here? On a 3b+ I cannot get audio via Bluetooth on a speaker running. Pairing with the speaker succeeded, but no sound.
I might have wrong settings in MPD and / or System settings.
Can someone help me on configuring bluetooth output?
Thanks and cheers. :-)
kolmberger
Re: RuneAudio+R e6
Postby rern » 03 Dec 2020, 12:10
