RuneAudio+R e6
Re: RuneAudio+R e6
Postby rern » 05 Dec 2020, 08:51
Re: RuneAudio+R e6
Postby ceejayemm » 05 Dec 2020, 10:08
Hi Rern
I am afraid the code above has no effect on the padlock on Systems / Features. I still get asked for a password when trying to access Features.
Regards.
Chris
ceejayemm
Re: RuneAudio+R e6
Postby rern » 05 Dec 2020, 10:43
Re: RuneAudio+R e6
Postby ceejayemm » 05 Dec 2020, 10:56
Rern
No joy, still the same. No login* files exist in /srv/http/data/system
Chris
ceejayemm
Re: RuneAudio+R e6
Postby ceejayemm » 05 Dec 2020, 11:09
@Rern
Interestingly I can still get to the Features page via the new Settings bottom bar. Does this giuve any clues.
Chris
ceejayemm
Re: RuneAudio+R e6
Postby bink » 05 Dec 2020, 11:39
bink
Re: RuneAudio+R e6
Postby Russ » 05 Dec 2020, 12:29
Russ
Re: RuneAudio+R e6
Postby RolandBlaze » 05 Dec 2020, 14:32
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Re: RuneAudio+R e6
Postby daoane » 05 Dec 2020, 19:28
daoane
Re: RuneAudio+R e6
Postby BVLabs » 07 Dec 2020, 10:02
Something went wrong again. I downloaded the latest firmware revision. Again does not receive an ip address from the access point.
BOOT.LOG
Dec 07 10:49:59 runeaudio hostapd[268]: Configuration file: /etc/hostapd/hostapd.conf
Dec 07 10:49:59 runeaudio dnsmasq[269]: dnsmasq: syntax check OK.
Dec 07 10:49:59 runeaudio systemd-networkd[214]: wlan0: Link UP
Dec 07 10:49:59 runeaudio hostapd[268]: wlan0: Could not connect to kernel driver
Dec 07 10:49:59 runeaudio hostapd[268]: Using interface wlan0 with hwaddr b8:27:eb:01:5c:6e and ssid "RuneAudio"
Dec 07 10:49:59 runeaudio hostapd[268]: random: Cannot read from /dev/random: Resource temporarily unavailable
Dec 07 10:49:59 runeaudio hostapd[268]: random: Only 0/20 bytes of strong random data available
Dec 07 10:49:59 runeaudio hostapd[268]: random: Not enough entropy pool available for secure operations
Dec 07 10:49:59 runeaudio hostapd[268]: WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects
Dec 07 10:49:59 runeaudio systemd-networkd[214]: eth0: DHCPv4 address 192.168.1.25/24 via 192.168.1.1
Dec 07 10:49:59 runeaudio systemd-timesyncd[242]: Network configuration changed, trying to establish connection.
Dec 07 10:49:59 runeaudio hostapd[268]: wlan0: interface state UNINITIALIZED->ENABLED
Dec 07 10:49:59 runeaudio systemd-networkd[214]: wlan0: Gained carrier
Dec 07 10:49:59 runeaudio hostapd[268]: wlan0: AP-ENABLED
Dec 07 10:49:59 runeaudio sshd[271]: Server listening on 0.0.0.0 port 22.
Dec 07 10:50:00 runeaudio systemd[1]: Finished Save/Restore Sound Card State.
Dec 07 10:50:00 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 07 10:50:00 runeaudio systemd[1]: Reached target Sound Card.
Dec 07 10:50:00 runeaudio systemd[1]: Started User Login Management.
Dec 07 10:50:00 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 07 10:50:00 runeaudio kernel: kauditd_printk_skb: 11 callbacks suppressed
Dec 07 10:50:00 runeaudio kernel: audit: type=1130 audit(1607331000.140:23): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 07 10:50:00 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 07 10:50:00 runeaudio systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Dec 07 10:50:00 runeaudio audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 07 10:50:00 runeaudio systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Dec 07 10:50:00 runeaudio avahi-daemon[267]: Successfully called chroot().
Dec 07 10:50:00 runeaudio kernel: audit: type=1130 audit(1607331000.150:24): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 07 10:50:00 runeaudio kernel: audit: type=1130 audit(1607331000.150:25): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 07 10:50:00 runeaudio avahi-daemon[267]: Successfully dropped remaining capabilities.
Dec 07 10:50:00 runeaudio dnsmasq[297]: started, version 2.82 cachesize 150
Dec 07 10:50:00 runeaudio dnsmasq[297]: compile time options: IPv6 GNU-getopt DBus no-UBus i18n IDN2 DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Dec 07 10:50:00 runeaudio dnsmasq[297]: DBus support enabled: connected to system bus
Dec 07 10:50:00 runeaudio dnsmasq[297]: warning: interface wlan0 does not currently exist
Dec 07 10:50:00 runeaudio dnsmasq-dhcp[297]: DHCP, IP range 192.168.5.2 -- 192.168.5.254, lease time 1d
Dec 07 10:50:00 runeaudio systemd[1]: Reached target Host and Network Name Lookups.
Dec 07 10:50:00 runeaudio dnsmasq[297]: reading /etc/resolv.conf
Dec 07 10:50:00 runeaudio dnsmasq[297]: using nameserver 217.19.208.19#53
Dec 07 10:50:00 runeaudio dnsmasq[297]: using nameserver 8.8.4.4#53
Dec 07 10:50:19 runeaudio systemd-timesyncd[242]: Initial synchronization to time server 178.17.160.12:123 (pool.ntp.org).
Dec 07 10:50:00 runeaudio dnsmasq[297]: cleared cache
Raspberry Pi 3 Model B Rev 1.2
Terra-Berry DAC2+
BVLabs
