RuneAudio+R e6
Re: RuneAudio+R e6
Postby alecs123 » 11 Dec 2020, 16:34
alecs123
Re: RuneAudio+R e6
Postby lnoferin » 11 Dec 2020, 17:52
lnoferin
Re: RuneAudio+R e6
Postby Jaymass » 11 Dec 2020, 23:55
This is fantastic! I’ve been struggling along with HiFiBerry os and Volumio neither of which are really usable with a touch screen,scrolling through tracks is sooooo slow, I stumbled over this forum post and I’m delighted,works exactly as I’d hoped it might! I do have a couple of questions though,I have a HiFiBerry Dac+ DSP on the way, I see it’s listed in the driver section does that mean I don’t need to instal the dsp tool kit or will I still need to when it arrives? Also is there a way to remove the volume control from the display,I’ve gone through settings a few times and can’t find an option? Thanks!
Edit: found the option for removing the volume display!
This software is fantastic, sounds gorgeous,looks great, functions smoothly and quickly ...honestly feels like an early Christmas present!
Jaymass
Re: RuneAudio+R e6
Postby ray1112 » 12 Dec 2020, 15:28
I have Cirrus Logic Audio Card and Raspberry Pi 2.
Version e6 20201201 • RuneAudio
Hardware Raspberry Pi 2 Model B Rev 1.1
Output Device Generic Cirrus Logic WM5102
Q1. How change audio card output (Line out or Headset)? RuneAudio 0.4b have it on MPD page.
Q2. Default mixer is not working (Hardware Volume Control is not working). RuneAudio 0.4b have it working well.
If I change mixer on MPD page to "HPOUT1 Digital" I have error on MPD page:
Errors: JSON.parse: unexpected character at line 1 column 118 of the JSON data
▮{ "devices" : [{ "aplayname" : "RPi-Cirrus" , "card" : 0 , "device" : 0 , "dop" : 0 , "format" : "" , "mixercount" : , "mixermanual" : "HPOUT1 Digital" , "mixertype" : "hardware" , "name" : "RPi-Cirrus" , "hw" : "hw:0,0" , "hwmixer" : "HPOUT1 Digital" }] , "audiooutput" : "Generic Cirrus Logic WM5102" , "audioaplayname" : "rpi-cirrus-wm5102" , "autoupdate" : false , "buffer" : false , "bufferset" : false , "bufferval" : false , "bufferoutput" : false , "bufferoutputset" : false , "bufferoutputval" : false , "crossfade" : false , "crossfadeset" : false , "crossfadeval" : false , "custom" : false , "customset" : false , "customval" : "customset" , "ffmpeg" : false , "normalization" : false , "reboot" : "" , "replaygain" : false , "replaygainset" : false , "replaygainval" : "" , "soxr" : false , "soxrset" : false , "soxrval" : "" , "usbdac" : "" }
Raspberry Pi 2 Model B Rev 1.1, Cirrus Logic Audio Card, RuneAudio 0.4b
ray1112
Re: RuneAudio+R e6
Postby Ears of Tin » 12 Dec 2020, 16:29
Ears of Tin
Re: RuneAudio+R e6
Postby Jaymass » 12 Dec 2020, 17:40
Thank you! I did find it after a while of playing, I also got an answer from HiFiBerry regarding the dsp board, it’s possible to use their os and save settings to the board itself then simply swap the card back to the rune one and the room correction,eqs etc will all still be active so a pretty simple solution there!
Loving the “roll the dice” mode, I may never turn this off again :)
Jaymass
Re: RuneAudio+R e6
Postby haddock » 13 Dec 2020, 12:51
Last weeks I've scrutenized my musiccollection for missing metadata en covers. After updating the library in runeaudio I notices a strange sorting order. Artistnames, bandnames starting with "The" are sorted apparently at random.
The sorted list starts with groups with names starting with "The". After that the other groups starting with "T" are listed. However in that list also groups with "The" are listed. The latter are not listed in the top part.
To visualize:
The 13th Floor Elevators
The Adverts
The Supremes
T'Pau
T. Rex
Taylor Swift
The Teardrops Explode
Tears for Fears
etc.
It looks like in some (random?) cases "The" is omitted.
In the metadata the names are spelled beginning with the. Listing the directory is also showing normal behaviour. List starts with T. Rex
Any ideas/suggestions?
Rpi 3B+, Allo Piano 2.1, RuneAudio+R e6
haddock
Re: RuneAudio+R e6
Postby Ears of Tin » 13 Dec 2020, 15:42
Ears of Tin
Re: RuneAudio+R e6
Postby rern » 14 Dec 2020, 14:05
Re: RuneAudio+R e6
Postby BVLabs » 14 Dec 2020, 14:47
Hi, Rern. Any good news about Access Point mode?
Raspberry Pi 3 Model B Rev 1.2
Terra-Berry DAC2+
BVLabs
