RuneAudio+R e6
Re: RuneAudio+R e6
Postby GriffinUcos » 18 Dec 2020, 18:02
Hello, All.
Greatly impressed with this excellent audio solution. I have an old Pi B+ running RuneAudio+Re6 and was able to get virtually everything working straight out of the "box".
I intend to buy a DAC and small amplifier, but in the meantime I wanted to cast the audio to my bluetooth tower across the office. I'm using a bluetooth dongle which works fine on a win 10 machine but I am clearly missing something important as the dongle doesn't seem to be detected. I've connected it direct and via a powered hub to no effect.
Perhaps some kind person can tell this old g*** where to look in the documentation so I can set it up?
Kind regards
Griff.
GriffinUcos
Re: RuneAudio+R e6
Postby Ears of Tin » 18 Dec 2020, 18:35
Ears of Tin
Re: RuneAudio+R e6
Postby GriffinUcos » 18 Dec 2020, 21:43
Thanks for the moral support EoT, we OGs need to stick together. I looked at some of your other posts which led me to track down /bluetooth main.conf.
Clearly I was over optimistic when I thought BT might be more automated in this version. Having found the conf I'll do some more research and I'll take it from there.
I realise now that I have been "spoilt" on my other Raspi projects.
Take care.
GriffinUcos
Re: RuneAudio+R e6
Postby ceejayemm » 18 Dec 2020, 23:06
@EarsofTin
To save searching the whole thread can you summarize how you have got Bluetooth audio working or point me to your original posting on this subject please ?
Chris
ceejayemm
Re: RuneAudio+R e6
Postby dryce » 19 Dec 2020, 03:34
dryce
Re: RuneAudio+R e6
Postby Ears of Tin » 19 Dec 2020, 06:49
Chris, re Bluetooth:
I've only used it in phone-to-Rune direction. Go to Settings/System and under On-Board Devices turn Bluetooth on and then reboot. After that "Rune" appears as an available device on my phone. I select Rune on the phone and play podcasts. Works as a sink/receiver very reliably for me.
To send, not so good. Go to Settings/Networks and Bluetooth devices should list after Wifi. Make sure your device (headphones in my case) is in pairing mode and then hit the search icon. Select the device from the newly generated list and pairing commences. I get the green okay light next to the listed device and my device indicates that it is paired. But no sound. Played with mixer and dac settings with no luck.
Ears of Tin
A New Release After +R e6
Postby rern » 19 Dec 2020, 08:34
Released for public beta testers on
Anyone with an extra micro SD card to spare should give it a try. Actually, for the cost of a new card today, everyone should.
Re: RuneAudio+R e6
Postby rern » 19 Dec 2020, 08:40
Re: RuneAudio+R e6
Postby rern » 19 Dec 2020, 09:08
Re: RuneAudio+R e6
Postby joe63 » 19 Dec 2020, 12:59
joe63
