RuneAudio+R e6
Re: RuneAudio+R e6
Postby rern » 21 Dec 2020, 16:11
Re: RuneAudio+R e6
Postby Ears of Tin » 21 Dec 2020, 18:11
I ran the 20201221 update this morning and BT is now working in both directions (sender and sink). Trying different files and have not encountered a problem file so far.
Thanks Rern
Ears of Tin
Re: RuneAudio+R e6
Postby haddock » 22 Dec 2020, 11:21
@rern
Testing the public beta rAudio 1 20201221 including the update. Sofar it is working great.
I did notice 2 points:
1. GPIO devices --> Audio I2s : the slider does not stick in position when activated. However the subject feature is activated and working.
2. Restoring a backup of RuneAudio+ Re6 is not working. I did find the backup file and the restore process seems to download/process the backup, but in the end no results visible.
thanks, regards
Rpi 3B+, Allo Piano 2.1, RuneAudio+R e6
haddock
Re: RuneAudio+R e6
Postby amonduulii » 23 Dec 2020, 03:19
I did the Addons update to 122120, rebuilt library and attempted reboot. I can no longer access ruenaudio through the normal "runeaudio.local" domain. I've also tried ssh to the actual IP# to no avail. The Raspberry Pi appears on my Router (Eero) as connected to the local IP address. Tried hard power reset on raspberry pi too. Any ideas of something else that can be tried?
I have a HiFi DigiBerry Pro DAC+ connected which worked perfectly up until now.
amonduulii
Re: RuneAudio+R e6
Postby cmh714 » 23 Dec 2020, 04:00
My only issue with the newest release is that my second NAS doesnt seem to want to mount automatically and I cant seem to figure it out. As soon as I do a remount its up in seconds......any ideas appreciated!
Both NAS are the same except for Size, both WD's one is 4TB and the other 2TB both almost full of flac, and running NFS. Not the biggest pain but....
TIA
Re: RuneAudio+R e6
Postby rastus » 23 Dec 2020, 04:15
rastus
Re: RuneAudio+R e6
Postby rastus » 23 Dec 2020, 04:18
rastus
Re: RuneAudio+R e6
Postby cmh714 » 23 Dec 2020, 04:19
Re: RuneAudio+R e6
Postby dryce » 23 Dec 2020, 05:23
dryce
Re: RuneAudio+R e6
Postby kailua » 23 Dec 2020, 13:36
kailua
