RuneAudio+R e6
Re: RuneAudio+R e6
Postby Beelzebassie » 16 Feb 2021, 09:28
Beelzebassie
Re: RuneAudio+R e6
Postby surfninja » 16 Feb 2021, 17:15
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Re: RuneAudio+R e6
Postby surfninja » 19 Feb 2021, 03:06
surfninja
Re: RuneAudio+R e6
Postby bink » 19 Feb 2021, 20:33
bink
Re: RuneAudio+R e6
Postby Caleb » 19 Feb 2021, 23:45
Can you tell me which display you are using? How is it connected?
Does the touchscreen work?
Can you write the contents of the touchscreen setup file?
I want to do as you do, but my display only shows a gray field and an arrow pointer.
Caleb
Re: RuneAudio+R e6
Postby bink » 20 Feb 2021, 09:17
bink
Re: RuneAudio+R e6
Postby Caleb » 20 Feb 2021, 10:17
Cool.
I see that it works.
When my sensor shows the pointer, it has one inverted vertical.
Caleb
Re: RuneAudio+R e6
Postby bink » 20 Feb 2021, 11:03
bink
Re: RuneAudio+R e6
Postby bink » 20 Feb 2021, 11:17
this is the original pcb of the linn and under the pcb is the powerboard where the first pin comes out exactly 5 volts dc, the rest of the pins have a higher voltage.
tonight I will continue ;)
bink
Re: RuneAudio+R e6
Postby Caleb » 20 Feb 2021, 15:34
I look forward to continuing.
My display.
https://aliexpress.ru/item/33041327727. ... 7335077076
Caleb
