RuneAudio+R e6
Re: RuneAudio+R e6
Postby bink » 20 Feb 2021, 23:15
bink
Re: RuneAudio+R e6
Postby Caleb » 20 Feb 2021, 23:25
Greetings.
I used this screen in conjunction with version 3b.
I used the firmware laid out at the beginning of the topic, without changes, only updated. Tomorrow I'll try to take a photo of his behavior.
Caleb
Re: RuneAudio+R e6
Postby Caleb » 20 Feb 2021, 23:28
I have only assembled raspberry + display, the display is connected directly to the raspberry.
I will use the player with Amanero+ galvanic isolation + AH-D6
http://audiohobby.ru/articles/vysokokac ... a-2-h.html
Caleb
Re: RuneAudio+R e6
Postby bink » 20 Feb 2021, 23:39
bink
Re: RuneAudio+R e6
Postby Caleb » 20 Feb 2021, 23:46
What version of firmware did you use?
can you upload the firmware image of your player to the cloud storage?
Caleb
Re: RuneAudio+R e6
Postby bink » 21 Feb 2021, 09:42
this morning flashed the last img of runeaudio and activated the 3.5 inch plugin, but unfortunately I also get a gray screen.
so what worked before about 2 months ago unfortunately no longer works.
bink
Re: RuneAudio+R e6
Postby bink » 21 Feb 2021, 09:45
bink
Re: RuneAudio+R e6
Postby rern » 21 Feb 2021, 09:48
As of 20201224, this has been upgraded to a .
Re: RuneAudio+R e6
Postby Caleb » 21 Feb 2021, 10:45
Hello.
It was this image that I used for Raspberry 3B, I just did not create an empty file lcd
maybe this is the problem
Caleb
Re: RuneAudio+R e6
Postby bink » 21 Feb 2021, 10:54
bink
