RuneAudio+R e6
Re: RuneAudio+R e6
Postby Russ » 26 Oct 2020, 09:11
Russ
Re: RuneAudio+R e6
Postby Russ » 26 Oct 2020, 09:29
Hi again guys,
Just to let you know that the wifi now works. I rebooted after all those reset commands listed above and when I tried again to connect to network, it detects the profile already existed (it did not before) and popped up a connect/forget option. Connected successfully. Now hopefully, there will be no issues on my home wifi later on.
While it resolves itself again this time, I would think there should be a longer term solution to this intermittent problem.
Russ
Re: RuneAudio+R e6
Postby R101 » 26 Oct 2020, 09:54
Hi rern,
After today's update, the system settings are not accessible from the menu.
Re: RuneAudio+R e6
Postby Russ » 26 Oct 2020, 09:58
Russ
Re: RuneAudio+R e6
Postby klassikmann » 26 Oct 2020, 11:31
klassikmann
Re: RuneAudio+R e6
Postby ceejayemm » 26 Oct 2020, 11:57
@rern / @klassicmann
I too can confirm that after todays update the main System page is not accessible (not the new Features submenu).
Chris
ceejayemm
Re: RuneAudio+R e6
Postby Beelzebassie » 26 Oct 2020, 12:02
To be specific: it's the "/index-settings.php?p=system" page that does not get loaded.
Beelzebassie
Re: RuneAudio+R e6
Postby klassikmann » 26 Oct 2020, 12:28
klassikmann
Re: RuneAudio+R e6
Postby RolandBlaze » 26 Oct 2020, 12:56
RuneAudio+R e6 20201108 
Raspberry Pi 4 Model B Rev 1.
RolandBlaze
Re: RuneAudio+R e6
Postby rern » 26 Oct 2020, 13:15
