RuneAudio+R e6
Re: RuneAudio+R e6
Postby dror » 30 Mar 2021, 16:49
How do I add the following address as webradio
http://s2.kzradio.net/live/mp3/icecast.audio
dror
Re: RuneAudio+R e6
Postby surfninja » 30 Mar 2021, 17:39
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Re: RuneAudio+R e6
Postby dror » 30 Mar 2021, 18:52
dror
Re: RuneAudio+R e6
Postby surfninja » 31 Mar 2021, 16:12
I seem to have lost my volume control with a recent update.
this is a Pi Zero with only usb out (no Audio I2S defined in the System page). I'm using a USB DAC (Behringer UCA202). I am able to control the volume from the USB DAC. I am able to listen to music through the USB DAC.
Is it possible to enable the volume control from my web browser?
i'm running 20210330.
< a few hours later>
I fixed this by enabling Player->Output->Volume Control = MPD Software
surfninja
Re: RuneAudio+R e6
Postby Beelzebassie » 01 Apr 2021, 10:42
20210330 disables WiFi with every reboot/restart. Can anyone confirm this behavior?
EDIT: Behavior persists, even with today's update (April 3rd) and a fresh image.
Beelzebassie
Re: RuneAudio+R e6
Postby giovilux » 03 Apr 2021, 12:06
I have done a fresh install today and wifi does not work.
I have created a wifi file and put it in the ROOT.
I see that it is enabled if I connect through LAN but it does not work.
Giovanni
giovilux
Re: RuneAudio+R e6
Postby bobbyb » 03 Apr 2021, 22:46
I am running the latest version RuneAudio+R e6, webplayer and streaming through upnp works fine but I failed to play songs through spotify connect. I have a premium account and I can play on other devices without problems.
I didn't change anything in the original configuration but activated spotify and upnp.
The songs seems to be playing through spotify but I cannot hear any sound. I tested it with different clients.
Volume is maxed out,
Running on Rpi1, wired connection.
Any idea what is going on and how to troubleshoot the issues?
Thanks for any help/advice
bobbyb
Re: RuneAudio+R e6
Postby AndyF » 04 Apr 2021, 10:16
Hi bobbyb,
you should change to rAudio1 (it´s Re6´s successor) - Re6 won´t be supported anymore.
https://github.com/rern/rAudio-1
Issues on rAudio1 should be discussed here:
https://github.com/rern/rAudio-1/discussions
I´m using latest version on RPi3 - and spotify works like a charm.
regards, Andy
AndyF
Re: RuneAudio+R e6
Postby bobbyb » 04 Apr 2021, 10:23
bobbyb
Re: RuneAudio+R e6
Postby dror » 04 Apr 2021, 16:23
It's actually been a while since I tried to play songs from my Nas, but I faced an issue.
Some songs or albums are not playable after added to the queue. Or, for others, the track length is not correct. Some though are playable.
I first thought it might have something with enabling FFmpeg, but it doesn't.
What I suspected next was the way rAudio interprets cue files. Didn't investigate too much but if I add a file/album with an external MPD remote (I use M.A.L.P which is awesome) it does add, and is playable even through rAudio web interface.
My version is 20210302
dror
