RuneAudio+R e6
Re: RuneAudio+R e6
Postby surfninja » 07 Apr 2021, 19:46
it will be interesting to see what Rune 2.0 (from the Rune team) looks like and if it will be adopted as much as Rern's rAudio solution. I'm a happy user of Rern's solution.
Or will we just continue to use Rurn's fork.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Re: RuneAudio+R e6
Postby rastus » 08 Apr 2021, 01:20
rastus
Re: RuneAudio+R e6
Postby surfninja » 09 Apr 2021, 06:21
surfninja
Re: RuneAudio+R e6
Postby deanpearl71 » 09 Apr 2021, 17:00
I ran the 20201221 update this morning with and BT is now working in both directions (sender and sink). Trying different files and have not encountered a problem file so far.
deanpearl71
Re: RuneAudio+R e6
Postby Beelzebassie » 15 Apr 2021, 08:40
rAudio (20210414) still keeps disabling WiFi with every reboot/restart. The WiFi settings themselves are kept.
Beelzebassie
Re: RuneAudio+R e6
Postby jaygothard » 15 Apr 2021, 22:53
Same here.
Rune is no longer usable for me for this reason.
Rune was working really great. It was super nice and then this issue just ran it into the ground. Not sure what or why.
jaygothard
Re: RuneAudio+R e6
Postby rern » 16 Apr 2021, 00:10
Re: RuneAudio+R e6
Postby Beelzebassie » 17 Apr 2021, 08:29
Beelzebassie
Re: RuneAudio+R e6
Postby Fito » 01 May 2021, 18:17
Hello folks,
currently I'm trying to setup an Raspberry Pi4 with an 3,5" Waveshare.
I flashed the image from the first page and generated an empty textfile named "lcd" in BOOT directory.
After connection via LAN I checked the point "enable TFT" in the system settings.
As it didn't work out, I did an update at the addons page, with no success
Another try with Volumio etc. did work out for the hardware.
But I would like to use RuneAudio, as there the GUI could be adjusted better.
Anyone having any hints for me ?
Best Regards,
FiTo
Fito
Re: RuneAudio+R e6
Postby rern » 03 May 2021, 10:13
Hi FiTo,
I've just tested it and it's still running fine. Post the link of product details of your Waveshare screen.
