RuneAudio+R e6
Re: RuneAudio+R e6
Postby Fito » 03 May 2021, 11:53
Hi Rern,
please find the attached Amazon Link
https://www.amazon.de/gp/product/B01N48 ... UTF8&psc=1
Also the backside of the PCB says "Rev2.0"
Does it something to do with the (A) or (B) version ?
I have an (B) version.
Best Regards,
Toby
Fito
Re: RuneAudio+R e6
Postby rern » 03 May 2021, 12:45
Re: RuneAudio+R e6
Postby Fito » 03 May 2021, 17:54
Great.
Many thanks for that solution.
It worked pretty fine.
I really appreciate it.
Fito
Re: RuneAudio+R e6
Postby rern » 07 May 2021, 14:06
Toby,
After applying 20210507 update, you have to select your display type in the option. Otherwise it will not work after reboot.
Re: RuneAudio+R e6
Postby tuxalator » 12 May 2021, 21:53
Running rAudio 1 on my RPI3. - 5.10.27-3-ARCH armv7l
For some reason I randomly cannot open some music maps on the NAS/MPD server.
I've checked and even set all permissions to 777 on maps and music files, to no avail.
What can that be?
tuxalator
Re: RuneAudio+R e6
Postby alphab0t » 19 May 2021, 03:18
running rAudio 1 - 20210414 on rpi4b 4gb with official touchscreen. bit-perfect playback with no volume.
There seems to be no rhyme or reason to WHEN it displays the bitrate information. Sometimes it's there and sometimes it isn't and I can't seem to reliably keep that information onscreen. I have thoroughly explored all items and menus but I find no toggle for this.
I searched several terms before creating an account to post my question, as I didn't find an answer.
Please let me know what I'm doing wrong. I'd like to make the bitrate information permanently displayed, maybe even a little bigger.
alphab0t
Re: RuneAudio+R e6
Postby krpepe » 25 May 2021, 01:03
Hello Rern,
Awesome work with your fork of rune! Absolutely love it!
Quick question, I have a nas with approximately 92,000 songs. I am running a raspberry pi 2b with 16g sd card. How long would you expect the MPD to build? I haven't had to rebuild the MPD for a long time but if my memory serves me correct it only took about 1.5 hrs the last time I did it. I am pushing 2.5 and not close to being done.
Thank you for all your hard work!!
Kevin
krpepe
Re: RuneAudio+R e6
Postby Ears of Tin » 25 May 2021, 14:17
Ears of Tin
Re: RuneAudio+R e6
Postby krpepe » 25 May 2021, 15:02
krpepe
Re: RuneAudio+R e6
Postby cmh714 » 25 May 2021, 16:03
if you dont need ffmpeg then turn it off.....that makes indexing go slow....GL!
