RuneAudio+R e6
Re: RuneAudio+R e6
Postby krpepe » 25 May 2021, 16:35
OK, so the library is built but if I click on the album picture to play the entire album it plays something that is not even in that folder. I am lost and I do not know how to fix this. It is also operating extremely slow. If I go to the play list nothing shows up even if something is playing in play back. To say the least this isn't working for me. I have it installed on 2 pi's one 2b and one 3b. I have tried reflashing the sd card multiple times with no change in behavior. Anyone have any ideas what I am doing wrong?
UPDATE: If you click the album cover to play the entire album it plays the first file in the entire library.
krpepe
Re: RuneAudio+R e6
Postby krpepe » 25 May 2021, 17:34
krpepe
Re: RuneAudio+R e6
Postby Ears of Tin » 25 May 2021, 19:45
Ears of Tin
Re: RuneAudio+R e6
Postby krpepe » 25 May 2021, 21:06
krpepe
Re: RuneAudio+R e6
Postby The Shocker » 26 May 2021, 16:40
I'm running Raudio-1 on a Raspberry Pi 3B+ with a HiFiberry DAC.
When I use the WebUI, if I switch browser tabs and then switch back to the tab that has Rune, it takes about 5 seconds for the UI to update. The song progress bar doesn't move, and no click register. After 5 seconds, the screen updates, and any clicks I did during the 5 second delay work.
So, I can pause, but the pause takes 5 seconds to respond. Once the 5 seconds pass, the webUI becomes very responsive.
The PI and the PC I am using are both connected via Gigabit Ethernet to the same switch.
Anyone know what's causing this delay in refresh? Is this because I am on a 3B+?
The Shocker
Re: RuneAudio+R e6
Postby Ears of Tin » 26 May 2021, 21:37
Ears of Tin
Re: RuneAudio+R e6
Postby surfninja » 27 May 2021, 18:58
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
Re: RuneAudio+R e6
Postby robinjamess » 29 Jun 2021, 21:34
robinjamess
Re: RuneAudio+R e6
Postby chasolla » 09 Sep 2021, 13:37
I did the latest update yesterday and it plays tracks from the playlist in random order.
Does anybody know how I can make it play in track order or is it something that needs fixing?
thanks
Chas
RPi 3b+ running Re6 and loving it.
chasolla
Re: RuneAudio+R e6
Postby Ears of Tin » 10 Sep 2021, 13:29
Sounds like shuffle mode or random play is on. In playlist screen are the crossed arrows or dice icons highlighted? It's been a long time since I used that version so I can't remember exactly what it looked like. Rune+Re6 was great but you may want to upgrade to it's successor rAudio. https://github.com/rern/rAudio-1
Ears of Tin
