RuneAudio+R e6
Re: RuneAudio+R e6
Postby kw* » 17 Apr 2022, 08:59
I‘m running rAudio-1 version 202204151 on a RasPi3B+. It works fine but local covers in album grid view. In play view the local cover is shown (one cover.jpg 600x600 per album folder).
I‘ve also tested soundirok (command „ ln -s /mnt/MPD /srv/http/music“). Within the program it works but I prefer web gui. Cleared cache, rebuilt database didn‘t help.
Where do I have to start in this version? Is coverart_ctl.php still the right approach? If so, where is the file stored?
Thanks and best regards,
Oliver
[edit]: I‘ve got it, missing writing permission. Never need it before at this point. ;)
Raspberry Pi 3 B+, rAudio-1 v20230101
kw*
Re: RuneAudio+R e6
Postby alfred0809 » 23 Apr 2022, 19:03
I made first experiences with the new Bluetooth audio support, receiver mode. I have no previous Linux bluetooth experience, so please read my post with a grain of salt.
alfred0809
Re: RuneAudio+R e6
Postby M.B. » 21 May 2022, 20:39
Hi together,
thanks for the great Job, very good and is working fine with a USB Bluetooth Receiver for my AmazonMusic.
BUT - question - is the http command system disabeld?
Because i use an loxone system and in previous Versions i could toggle play pause and setvol with the commands:
http://ipofmyruneaudio/command/?cmd=play or pause or setvol
Since the Update this doesn't work any more.... any ideas? Or is it in the new version not more implemented?
Is there a new syntex which i did not see?
M.B.
Re: RuneAudio+R e6
Postby Noeldibua » 22 Jun 2022, 00:47
Hello to all !
Thanks for the great job called rAudio 1 !
I got a small problem I can not solve nor found a log file...
Running rAudio 1 • 20220618 on a Rsapberry Pi 2 Vers 1.1 - plain installation (ex fixed IP Adr) no changes done so far. But: Any time I do a reboot the Network mount´s are gone. Error Message on the GUI start is "NAS @ cannot be reached"
Adding them with
mount -t cifs "//10.0.0.180/media/Musik/Sampler" "/mnt/MPD/NAS/Sampler" -o noauto,username=nur,password=nuralle,iocharset=utf8
or
mount -t cifs "//10.0.0.180/media/Musik/Sampler" "/mnt/MPD/NAS/Sampler" -o username=nur,password=nuralle,iocharset=utf8
does bring me back the directories and files on my nas.
Any solution or any way to find a log file dealing with this ?
Thank you for reading this.
Noeldi
BTW: Why is a "noauto" in the mount options ?
Noeldibua
Re: RuneAudio+R e6
Postby kw* » 22 Jun 2022, 05:57
@Noeldibua:
I had the same here. What helped for me:
I took a closer look at the settings/system/storage...and pushed the question mark button.
Until now I didn't give my NAS a separate name just set the music directory and the user/password. Now I followed the pic's advise, made a directory and adopted the path.
Second: fstab...i put in SMB version to vers=3.0 (Synology NAS is capable to min=1.0, max=3.0)
Two reboots and directory is remount. Up to now it works.
kw*
Re: RuneAudio+R e6
Postby Noeldibua » 22 Jun 2022, 13:41
Ohhh... Stupid me !!! There´s a GUI for adding storage !!!!! I just did not see the "+"
Sorry, sorry sorry... Everything is working fine....
:roll: :o
Of course I did make a donation now...
Noeldibua
Re: RuneAudio+R e6
Postby farrellts » 07 Jul 2022, 00:17
Just today discovered RuneAudio+Re6 and installed on an old first-generation Pi. No problems with install and accessing the browser-based UI on various devices on my LAN. However, I cannot find any way to connect to my MP3 library contained in an SMB share on another host (Samba running in Raspian on a Pi4). I've clicked everything which can be clicked on the RuneAudio+R6 web browser UI, and am not finding any way to accomplish this. (This was very easy to do on the original RuneAudio!) Also not finding docs on RuneAudio+Re6 and so please forgive me for having to ask this question: What do I need to do to connect RuneAudio+Re6 to an SMB share? (Sorry if I'm mixing Linux and Windows terms here....)
Thanks very much! I can supply more details but wanted to start off asking my question as succinctly as possible.
farrellts
Re: RuneAudio+R e6
Postby farrellts » 07 Jul 2022, 16:14
Okay, I figured out that I need to mkdir a mountpoint, then change fstab to permanently mount my remote Samba share. Not ideal but I'll take it for now.
Now the issue is getting Wifi to work. Reliably. I can only get Wifi to connect while I have an ethernet cable attached. I can only "Connect" to Wifi under those circumstances. I have my doubts as to whether Wifi gets connected at all, since, as soon as I remove the ethernent cable, all connectivity ceases. I'm going to search this thread, but any pointers would be appreciated.
farrellts
Re: RuneAudio+R e6
Postby giovilux » 09 Jul 2022, 14:50
giovilux
Re: RuneAudio+R e6
Postby rern » 10 Jul 2022, 07:57
@farrellts,
Giovanni,
A fix for Wi-Fi: Please try the latest update, 202207101 or later.
@farrellts,
Add a network share: Settings > System > Storage - plus button
