RuneAudio+R e6
Re: RuneAudio+R e6
Postby Beelzebassie » 29 Oct 2020, 10:57
Beelzebassie
Re: RuneAudio+R e6
Postby Beelzebassie » 29 Oct 2020, 11:04
@rern
Is there a way to see how much memory of max_output_buffer_size is actually used?
Beelzebassie
Re: RuneAudio+R e6
Postby kailua » 29 Oct 2020, 17:51
Great work, it is playing happily! But how can I play the audio via my Bluetooth speaker? It is paired and connected according to the Network menu. Where is the option to redirect audio to the BT speaker?
kailua
Re: RuneAudio+R e6
Postby kiko » 29 Oct 2020, 20:02
I solved the issue with my two IP addresses by rebuilding iTunes as ITunes1.
I also re-installed R-e6 as every time I would access the System page and try to leave it, I would reboot the system as it could not contact the 172.30.10.3 address, even though the mounts were mounted.
Now, that issue is also gone.
I still have the
Oct 29 09:43 : exception: error on client 20: Output buffer is full
Issue
kiko
Re: RuneAudio+R e6
Postby amonduulii » 29 Oct 2020, 23:29
amonduulii
Re: RuneAudio+R e6
Postby Beelzebassie » 30 Oct 2020, 18:45
Beelzebassie
Re: RuneAudio+R e6
Postby amonduulii » 31 Oct 2020, 02:21
Thank you! This solved it.
amonduulii
Re: RuneAudio+R e6
Postby klassikmann » 01 Nov 2020, 09:24
klassikmann
Re: RuneAudio+R e6
Postby ceejayemm » 01 Nov 2020, 10:57
@rern
How do I now enable the on-board browser to use RA+Re6 with an RPI Touchscreen ? The option to enable the browser seems to have disappeared from the System or Features pages. Has it been renamed or am I missing it elsewhere ?
Chris
ceejayemm
Re: RuneAudio+R e6
Postby klassikmann » 01 Nov 2020, 11:42
klassikmann
