RuneAudio+R e6
RuneAudio+R e6
Postby rern » 19 Oct 2020, 05:44
Re: RuneAudio+R e6
Postby rastus » 19 Oct 2020, 08:05
rastus
Re: RuneAudio+R e6
Postby klassikmann » 19 Oct 2020, 10:44
klassikmann
Re: RuneAudio+R e6
Postby PatiTati » 19 Oct 2020, 12:55
nice work! I have problems with 2 functions.
1. Password Protection dont work. If i turn the protection on the UI says "Default Password is: rune"
The password rune did not work for me. Also i can not change the password because it says "wrong Password"
2. Volume Slider on iPhone reacts if i swipe up and down trough the page. Only if i start swipe up or down on the slider but thats not good. I think it would be better to be able to change the volume only when I press the volume slider. (like a Volume Popup Box)
Runs on a RaspiPi 4 with latest release (20201019)
Best regards
Patrick
PatiTati
Re: RuneAudio+R e6
Postby Alien8 » 19 Oct 2020, 21:45
Hi Rern
My Re2 setup went south last week and I've now have been running the Re5 since then and the Re6 is now spinning nicely.
Setup is a breeze and its nice to see a pretty much matured system. Hats off to you Rern.
I did have a slight issue with those cover arts again, just like forum member Matt had brought up for Re5. Its the same in this version too...
After adding my NAS and the library scan, when I go to album view in the library page, I see the re default covers. When I click the button in the top bar, I get the dialog to start scanning for covers. When clicked the script starts rolling out that no covers are found for ARTIST xx and none are found.
I believe it should compare albums instead of artists there.
In my older Re2 it found most if not all covers, my nas db didn't change.
And when I click an album in the album view, I do get the cover as it should, and I have the option to use this cover in album view, so that works fine too .
Otherwise I didn't found any issues...
HTH A8
Alien8
Re: RuneAudio+R e6
Postby rern » 20 Oct 2020, 03:37
Re: RuneAudio+R e6
Postby rern » 20 Oct 2020, 14:55
Re: RuneAudio+R e6
Postby R101 » 20 Oct 2020, 16:29
Hi rern,
I notice that the alphabetical selection bar does not work in the Webradio library page.
Re: RuneAudio+R e6
Postby klassikmann » 20 Oct 2020, 17:10
klassikmann
Re: RuneAudio+R e6
Postby Ears of Tin » 20 Oct 2020, 19:21
Was successful in installing, connecting to my network and building library. But having a problem installing my I2S DAC. In System settings I select appropriate I2S module but it doesn't stick (reverts to disabled). Under MPD settings, audio output device gives choice of headphone/hdmi rather than my selected DAC.
Same hardware (RPi3B and Hifiberry DAC+) runs re5 without problems. I'll revert to 5 for now til I have more time to research. Since I'm a simple man I hope this is a simple problem.
Ears of Tin
