Runeaudio still broken :-( Volumio 1.55 still works - sorry.
Postby piercer » 25 Apr 2015, 10:46
A while ago I tried to use Runeaudio but found that both bonjour and airplay did not work on it.
The Raspberry Pi cannot be found by bonjour and airplay is really bad with incredible electronic distortion.
I switched to volumio and it worked perfectly out of the box.
Recently I got a Raspberry Pi 2 and thought I would try the Runeaudio image for it.
Amazingly it still won't work for me with exactly the same problems.
So with Raspberry Pi A, Raspberry Pi 2, Chord Hugo DAC and Chord 2Qute DAC Runeaudio is essentially usueless, but volumio works out the box.
Can anybody help getting runaudio working for me?
piercer
Re: Runeaudio still broken :-( Volumio 1.55 still works - so
Postby hondagx35 » 25 Apr 2015, 12:30
Postby J@r0d » 26 Apr 2015, 06:34
I have test your link and this is no functionnaly, the sound is distorded before and after modification :oops:
J@r0d
Postby Aquarius » 27 Apr 2015, 08:58
Bonjour and Airplay are "sound system" protocols. Designed to get you to stream music and downmixing everything to a fixed sampling rate, lowering the sound quality in the process.
While it's probably nice to have those around, I beleive the stated goal of RuneAudio is hifi. This means bit perfect as far as possible. So I understand if those "lesser" means of use are not as polished as the rest of the system. (yes, having both work well would be even better :) )
-- Aquarius
Aquarius
Postby hondagx35 » 27 Apr 2015, 11:56
Postby Aquarius » 28 Apr 2015, 09:00
Thanks for the clarification, Frank!
Downmixing is supposed to be bad, whatever the rate, but I see your point.
Cheers!
-- Aquarius
Aquarius
Postby J@r0d » 28 Apr 2015, 20:17
J@r0d
Postby Da Alchemist » 29 Apr 2015, 13:34
Da Alchemist
Postby J@r0d » 01 May 2015, 15:46
J@r0d
