Rasp Pi 3B with Digi+ Music files are stored on connected USB.
I'm not linux savvy.
I just flashed Rune0.5 + RuneUIe (Pre-installed). Got up and running fine. Was trying to figure out the tag editor and the UI stopped responding (music remaining in cue continued to play). I can access through terminal.
systemctl status yields:
● runeaudio
State: degraded
Jobs: 0 queued
Failed: 1 units
Since: Wed 1969-12-31 19:00:05 EST; 49 years 7 months ago
CGroup: /
├─init.scope
│ └─1 /sbin/init
└─system.slice
├─rune_SY_wrk.service
│ └─383 /usr/bin/php /var/www/command/rune_SY_wrk
├─systemd-timesyncd.service
│ └─245 /usr/lib/systemd/systemd-timesyncd
├─mpd.service
│ └─25352 /usr/bin/mpd --no-daemon
├─nginx.service
│ ├─293 nginx: master process /usr/bin/nginx -g pid /run/nginx.pid>
│ └─294 nginx: worker process
├─hostapd.service
│ └─956 /usr/bin/hostapd /etc/hostapd/hostapd.conf
├─dbus.service
│ └─258 /usr/bin/dbus-daemon --system --address=systemd: --nofork >
├─brcm43438.service
│ └─250 /usr/bin/hciattach -n /dev/ttyAMA0 bcm43xx 921600 noflow -
├─sshd.service
│ ├─ 284 /usr/bin/sshd -D
│ ├─1196 sshd: root@pts/0
│ ├─1198 -bash
│ ├─1249 systemctl status
│ └─1250 less
├─avahi-daemon.service
│ ├─253 avahi-daemon: running [runeaudio.local]
│ └─276 avahi-daemon: chroot helper
├─systemd-resolved.service
│ └─246 /usr/lib/systemd/systemd-resolved
├─polkit.service
│ └─24887 /usr/lib/polkit-1/polkitd --no-debug
├─rune_PL_wrk.service
│ └─757 /usr/bin/php /var/www/command/rune_PL_wrk
├─system-netctl\x2difplugd.slice
│ └─netctl-ifplugd@eth0.service
│ ├─257 /usr/bin/ifplugd -i eth0 -r /etc/ifplugd/netctl.action ->
│ └─368 dhcpcd -4 -q -t 30 -L eth0
├─systemd-udevd.service
│ └─210 /usr/lib/systemd/systemd-udevd
├─php-fpm.service
│ ├─ 724 php-fpm: master process (/etc/php/php-fpm.conf)
│ ├─ 737 php-fpm: pool command
│ ├─ 738 php-fpm: pool db
│ ├─ 739 php-fpm: pool display
│ ├─32430 sh -c cd '/srv/http' ; /usr/bin/sudo /usr/bin/kid3-cli ">
│ ├─32455 /bin/bash /srv/http/enhancecount.sh 1
│ └─32456 mpc idle update
├─cronie.service
│ └─256 /usr/bin/crond -n
├─systemd-journald.service
│ └─198 /usr/lib/systemd/systemd-journald
├─haveged.service
│ └─255 /usr/bin/haveged -F -w 1024 -v 1
├─mpd-watchdog.service
│ ├─ 252 /usr/bin/sh /var/www/command/mpd-watchdog
│ └─1247 sleep 10
└─redis.service
└─289 /usr/bin/redis-server 127.0.0.1:6379
What to do?
Thanks! Runeaudio is truly great.
