RuneAudio V0.4 does not recognize RP2 HiFiBerryDAC+ (solved)
Postby Herr Flick » 20 Oct 2016, 12:05
Hi there,
I,am running RP2 with HiFiBerryDAC+ controlled by RuneAudi V0.3 with great succes! But now I tried to upgrade RuneAudio to:
release version: 0.4 (build: beta-20160313)
But the problem is it does not regocnize my HiFiBerryDAC+ anymore. After several restarts I could once choose in -Audio output interface- my HiFiBerryDAC+.
Back to RuneAudio V0.3 there is no problem at all, I can enjoy the superb soundquality as usual.
Thanks for your help in advanced.
###### System info ######
Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
system time: Thu Oct 20 12:28:04 CEST 2016
system load: 0.38 0.11 0.04 2/144 749
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
Herr Flick
Re: RuneAudio V0.4 does not recognize RP2 & HiFiBerryDAC+
Postby hondagx35 » 20 Oct 2016, 16:15
Hi Herr Flick,
did you enable your DAC in /boot/config.txt?
Postby Herr Flick » 20 Oct 2016, 19:21
I `am afraid NOT! I give it a try, thanks..
Herr Flick
Postby Herr Flick » 21 Oct 2016, 13:40
That works for me...Frank!
RuneAudio V0.4 + Rasberry Pi2 & HiFiBerryDAC+ Up and running!
My HiFi equipment:
"Elektor" PreAmplifier, home made
Build in Rasberry Pi 2B & HiFi BerryDAC+ with a 5Volt 2 A home made power supply
"Elektor" Class A amplifier 2x25 Watt, home made
Acoustic Energy AE2 loudspeakers with Vibrapod isolators
Greetings from The Netherlands.
Herr Flick
Re: RuneAudio V0.4 does not recognize RP2 HiFiBerryDAC+ (sol
Postby surfninja » 21 Oct 2016, 15:40
Herr Flick,
thanks for posting your hi fi gear. I enjoy seeing what others are using.
I've built a few pre amps (6sn7 buffer, solid state based off of a DH-101) and many tube amps. Nothing Class A.
rAudio 1, Raspberry Pi 2B
rAudio 1, Raspberry Pi 4B
rAudio 1, Raspberry Pi Zero W
surfninja
