RuneOS crash kernel on fresh install
Postby Oberon » 29 Nov 2015, 17:31
Hi runeaudio team,
After some reasearch I wanted to give a shot at rune audio to replace my aging LMS server.
My setup:
1) Raspberry Pi 2 Model B
2) Raspberry Pi PSU (OUTPUT 5V, 1.0A)
2) RuneOS 0.3-beta flashed with USB Image Tool
3) 3 different SD cards (SanDisk, Kingston, NoName)
4) Plugged to an HD projector via HDMI
5) Nothing else plugged in the unit
After a fresh install the kernel crashes somewhere during the booting phase.
I managed to take a snapshot of the end of the booting phase which shows the kernel crash:
Anybody with some ideas why a fresh install would fail like this?
Oberon
Re: RuneOS crash kernel on fresh install
Postby hondagx35 » 29 Nov 2015, 20:55
Hi Oberon,
this is strange.
Did you try to boot without the projector and access Rune via its webinterface?
I only had something like this once and it was the usb keyboard.
Postby Oberon » 29 Nov 2015, 23:17
Frank,
The unit also crash when I disconnect the projector.
As a side note, I flashed the latest image of Volumio and my Pi boots perfectly. I really want to try out rune audio and I'm a bit lost as to what I should do next.
How can I get a full log of the booting phase?
Can I build a RuneOS image from source?
Can I selectively disable kernel modules?
Any help is appreciated.
Oberon
Postby hondagx35 » 29 Nov 2015, 23:22
Is it this image?
RuneAudio_rpi2_0.3-beta_20150304_2GB.img
Postby Oberon » 29 Nov 2015, 23:34
Yes I think so:
RuneAudio_rpi2_0.3-beta_20150304_2GB.img.gz
634.382.055 bytes
WinMD5 -> ce3ab67ce10fa52b3eb3314a968d3cb8
Oberon
Postby Oberon » 12 Dec 2015, 23:09
Trying the same SD card on a different Pi unit actually solved the issue.
I probably had a defective unit :(
Thread closed.
Oberon
