RuneOS - DIY RuneAudio+R e
Postby rern » 09 Nov 2019, 08:45
Re: RuneOS - DIY RuneAudio+R e
Postby klassikmann » 09 Nov 2019, 15:03
My first experiences with the released DIY version.
But first: Full respect to Rern's work.
My environment:
- Ubuntu 19.10 (64Bit) on Ryzen 2700x
- Hardware: Raspberry Pi 3 Model B Rev 1.2
- DAC^h-^h-^h-DigitalOut: HifiBerry Digi+ Pro (I2S)
- Micro SD card only
- Existing data-folder saved as tar-file
- Music on a CIFS-share
In my first try I restricted the optional features to a minimum: Avahi (for convenience) and FFmpeg (needed to decode .ts (MPEG Transport streams). Generation of RuneAudio runs smoothly. At the end I exchanged the fresh data-folder with the contents of my tar-file and restored database and settings with the corresponding addons-function. In the log of "Restore settings" I detected many ESC-sequences and "Failed to" messages which are not surprising because the corresponding services (shairport-sync, localbrowser, nmb, upmpdcli) had been excluded. Although "Restore mounts" should be successful, the CIFS-share was not available (I'll come to that below).
I restarted the DIY process maintaining all optional services and proceeded as above. Again, same CIFS-share problem. Reason: The mount-point of the share under /mnt/MPD/NAS was missing. After creation of the directory and subsequent manual mount the network share was available.
Summary:
- Everything o.k.
- Have a look at the mount-point for network shares
klassikmann
klassikmann
Postby klassikmann » 09 Nov 2019, 15:39
I found a regression.
The problem described in (coverart generation and .mpdignore) is back again.
klassikmann
klassikmann
Postby AndyF » 09 Nov 2019, 17:56
Test result with all available features: everything's OK.
Awesome work!
My environment:
- Linux Mint 19.1 on an old HP6730s
- RPi 3 with HifiBerry DAC+
- all-on-MicroSD mode
- music on an NFS share
Regards, Andy
AndyF
Postby rern » 10 Nov 2019, 08:45
Postby klassikmann » 10 Nov 2019, 13:43
klassikmann
Postby s.k. » 11 Nov 2019, 09:41
Nice job Rern, many thanks for your efforts!
My environment:
- Windows 10 desktop PC
- RPi 2 with Allo DigiOne
- music on an Samba share
After a lot of try’s & fails I manage to install it finally last night.
I started by setting up a static IP.
The IP changes to static but after a reboot it turned to previous status.
It seems that the settings aren’t stored.
I think the I2S settings don’t stored as well.
Does anyone face the same issue ?
I’ll continue the tests and I’ll report back.
Note:
As an average Windows User, dealing with VirtualBox was a pain in the butt.
I tried different tutorials regarding mounting the SDcard with little success (I had access denied issues)
and when I was finally succeeded, Rerns script gave me errors.
At the end the easiest way was to boot the PC from a USB flash drive with Kali Linux.
Tip for aspiring testers:
During the script execution be patient – it takes some time.
When you discover Raspberry’s IP, write it down.
If you don’t remember the IP you have to start the prosses all over again.
Best regards
Stavros
s.k.
Postby Mainstreet » 11 Nov 2019, 19:34
Hi, Rern!
Trying to build my Runeaudio on RPi 3A+ . Running create-rune.sh script after Installing customized packages and webinterface I get continious Packages download incomplete!. Internet connection is fast and stable. Do you have any ideas?
Regards!
Mainstreet
Postby rern » 12 Nov 2019, 13:16
Postby rern » 12 Nov 2019, 13:50
Users browsing this forum: Baidu [Spider] and 8 guests
