RuneUI 404 Not Found
Postby Bryce » 19 Nov 2016, 23:12
Recently, I got a new USB WiFi adapter for my Raspberry Pi. After I finished installing the drivers for it, I encountered the problem of the web interface for rune audio returning 404 Not Found. I am unsure how to fix this, any help would be appreciated.
Bryce
Re: RuneUI 404 Not Found
Postby hondagx35 » 20 Nov 2016, 00:25
Postby Bryce » 20 Nov 2016, 00:45
I did use that command. I will retry the process without it.
Bryce
Postby Bryce » 20 Nov 2016, 04:17
I got it working, thank you for the response. In-case anyone else stumbles on this thread, I got my packages from here: http://tardis.tiny-vps.com/aarm/packages/
Bryce
Postby trumpy81 » 20 Nov 2016, 14:51
Hi all,
I am also getting the dreaded 404 not found when I boot up my RPi3 with RPi Foundation 7" touch screen.
Sometimes I have to reboot the RPi3 a few times before it will boot into Rune Audio, otherwise I just get a white screen with the following.
404 not Found
Nginx /1.4.7
I don't believe I have made any recent changes to the Rune settings or hardware at all. I do have both the inbuilt wireless and an Ethernet connection on the RPi3 and I am wondering if that is somehow causing the issue.
Any help would be appreciated.
Andy M
Raspberry Pi 3 Model B + 7" Touch Screen + ABS enclosure - Raspberry Pi 2 Model B + Wavshare 7" IPS + HiFiberry DAC+ Pro + Bicolor Case - Synology DS1813+ with 8 x 4TB
trumpy81
Postby hondagx35 » 20 Nov 2016, 16:36
Postby trumpy81 » 20 Nov 2016, 16:58
Andy M
trumpy81
Postby trumpy81 » 24 Nov 2016, 16:02
Just thought I'd let you know that the RPi/Rune Audio has fixed itself.
I did not do anything to the RPi or Rune at all, but for some reason it has started to behave itself and it is now working better than it ever has.
The touchscreen has never been very sensitive to the touch, but even that has improved, it's not perfect, but it is certainly better than it was before!
I was thinking about rewriting the MicroSD card, but now there is no need. I can only imagine that the issue was somehow related to my network as I had an issue seeing SMB devices on my PC and that mysteriously fixed itself also.
In any case, I am a happy little chappy once again, thanks for the help though Frank, it is always appreciated. :)
Andy M
trumpy81
Postby hondagx35 » 24 Nov 2016, 16:52
Postby trumpy81 » 24 Nov 2016, 17:09
Actually, that would be a great idea, especially where WiFi is concerned.
I have found with the built-in wireless on an RPi3, you suffer from a lot of dropouts and even when adding a USB wireless dongle, wireless does not perform all that well.
I went as far as installing a WiFi Extender and while it did improve things a lot, it still did not eliminate the dropouts, for me at least. Now, I am connected by both Wireless and Ethernet and the network performance is very good indeed, no dropouts at all. :)
I only have the built-in wireless connected because I am not sure how to disable it correctly. :lol:
Anyhow, having some sort of graph or numerical output to show connection speed or signal strength would definitely help track down any connection issues someone might be having or at least allow you to report good/poor network performance.
Nice one Frank! :)
Andy M
trumpy81
Users browsing this forum: Baidu [Spider] and 23 guests
