RuneUI acces from login prompt
Postby shadowedefx » 21 Jan 2019, 01:36
New to RuneAudio. Installing to rpi3 with waveshare pearspot 4" Lcd. installed drivers thru Putty everything went off without a hitch. But on reboot system now stays on login without returning to the UI, Is the a way to return to the UI from the login, or is using a LDC other then one that is HDMI? If not Ill push forward with a different system that supports a GPIO LCD . Thanks for any assistance in advance.
(before i receive the ramdon smarta$$ reply about modify the script for the LCD driver...yes I read read the statement against doing so)
sudo mkdir /etc/X11/xorg.conf.d
(already exist)
sudo cp ./waveshare35a-overlay.dtb /boot/overlays/
sudo cp -rf ./etc/X11/xorg.conf.d/99-calibration.conf-4 /etc/X11/xorg.conf.d/99-calibration.conf
sudo cp -rf ./usr/share/X11/xorg.conf.d/99-fbturbo.conf /usr/share/X11/xorg.conf.d/
sudo cp ./cmdline.txt /boot/
sudo cp ./inittab /etc/
sudo cp ./boot/config-4.txt /boot/config.txt
sudo reboot
shadowedefx
Re: RuneUI acces from login prompt
Postby belgarath0815 » 21 Jan 2019, 19:18
GPIO LCD is definitely working, installed one yesterday, and it works fine
(btw I didn't modify any script, just enabled screensaver with xset)
Just to be sure, did you enable the local display in the settings?
Its not showing anything if you don't switch local browser to on in the settings
belgarath0815
