[Addon] RuneUI Enhancement
Postby Ripa » 24 Aug 2018, 14:02
Hi Rern,
I use the original 7 inch display now i see when startup all kind of source code.
It dont look nice anymore.....
Ripa
Ripa
Postby klassikmann » 24 Aug 2018, 18:19
klassikmann
Postby R101 » 24 Aug 2018, 21:38
Since this latest update, my 7" Android tablet displays a blank webpage. All seems OK on the PC.
Postby rern » 25 Aug 2018, 05:45
Ripa, R101,
Midori, the local RPi browser, and some browsers don't like a default variable syntax for functions which just added to the update.
It's fixed.
@R101 - How's the fix for sorting issue?
Postby R101 » 25 Aug 2018, 11:14
Thanks rern. Everything is working well now. The sorting issue was fixed by your previous update, so thanks again for that.
Postby Ripa » 27 Aug 2018, 12:28
Hi Rern,
everything seems to work perfect now.
is there a way to switch update off i have make an back up.
that way i first test the new version before i change the update.
thanks man for all the work...
Ripa
Hi Rern,
if i switch power off the display wich connected to the raspberry goes on and off
how can i fix this?
thanks
Ripa
Ripa
Postby Ripa » 28 Aug 2018, 09:51
Hi Rern,
today i try to start the system up but it stays in an loop.
it still trying to start up.
so it works when you reboot the system, but when you use switch off it stays in the loop
Ripa
Ripa
Postby alecs123 » 01 Sep 2018, 01:52
Hello... I installed the UI enhancement, it works perfect on my Lenovo Android tablet along with the RuneAudio app for remote control. But on my Phone, Also an Android the same RuneAudio app I can't turn off the autohide behavior, and can't access the gear menu for all setup and config needs, is There a way to turn off autohide?
alecs123
Postby rern » 01 Sep 2018, 05:23
Postby Ripa » 01 Sep 2018, 11:47
Hi Rern,
still have the problem that when i startup the system indicate 3 usb instead of only one the same with network
he seems to remember if you have use 3 usb.
Ripa
Ripa
