[Addon] RuneUI Enhancement
Postby rlsten » 25 Oct 2018, 19:47
rlsten
Postby MikeC » 27 Oct 2018, 18:18
I would like to note that I had the similar issues as Rod (previous post) with this release. I could not add to the playlist from my library, only WebRadio.
I was using a Pi3B+ and .5-beta. I don't use a local screen, so I could not test issues related to that.
Mike C
MikeC
Postby rern » 28 Oct 2018, 17:28
Postby rlsten » 29 Oct 2018, 15:19
rlsten
Postby cmh714 » 29 Oct 2018, 16:07
looking good as always @rern, thanks!
This is a sort of dumb request.....is there any way we can get the McIntosh VU meters in the UI?? I think the Mc radio app uses them....
TIA
***EDIT: ok I see its just an animated gif that I can probably replace.....
Postby Toube » 30 Oct 2018, 10:07
Hi @rern,
using 0.5 version and I also noticed some things that are not working:
- When browsing music library and selecting Add and Play, the album is added to the playlist but it will not start to play
- For the webradio the counter is not working in the now playing window, the counter is shown in the playlist though
- .cue or .m3u files using network share, not able to add to the playlist or play (Using normal UI these are working)
Regards,
Toube
Toube
Postby rlsten » 30 Oct 2018, 14:47
Tried the Adafruit 2.8" capacitive screen and still no ability to swipe. I am able to swipe with older versions of UI enhancements. Also, the index bar doesn't work on any screen; the number sign #, however, does return to the top.
Despite these issues, the latest UI enhancements are the best yet, and the major elements work very well.
Rod
rlsten
Postby MikeC » 30 Oct 2018, 18:00
You are making fantastic progress.
I have a couple of minor issues on my installs:
This applies to the .5 beta
UI version: 20181029
Both a Pi2B and Pi3B
1. Settings menu does not drop down on phone display - I tried multiple phones
2. To update music catalog I had go back two folders and run tool
It indicates that the update was finished but does not show new material until i rerun at least two folders up
The update function also returns to main library screen instead of display staying at proper folder level - This applies to computer screen and phones.
MikeC
MikeC
Postby cmh714 » 30 Oct 2018, 18:51
Postby MikeC » 31 Oct 2018, 20:40
I went back for a retest on the gear icon drop down menu on my phones.
It turns out that it is only broken in verticle mode.
If I turn my phone for landscape mode the drop down menu works fine.
MikeC
MikeC
