[Addon] RuneUI Enhancement
Postby rern » 03 Nov 2018, 14:53
Postby Toube » 03 Nov 2018, 15:42
Hi @rern,
Great news and great job once again.
I'll try it out immediately.
Thanks again.
Regards,
Toube
Toube
Postby R101 » 03 Nov 2018, 16:27
Many thanks to you and everyone involved rern. The current UIe is certainly working well.
Postby Toube » 03 Nov 2018, 19:45
Hi @rern,
I can't get all my .cue or .m3u playlists to load. Some load and some don't.
Regards,
Toube
Toube
Postby Toube » 04 Nov 2018, 08:19
Ok,
I was a bit too quick. It seems that the same .cue files are not loading using the normal UI either.
Most are still working though.
-Toube
Toube
Postby rern » 04 Nov 2018, 08:36
Postby Toube » 04 Nov 2018, 09:10
Toube
Postby Toube » 04 Nov 2018, 09:21
Hi @rern,
I think there is also something buggy in the Library for the Album, Artist, Album Artist, Composer and Genre navigation.
If I select Album and go in to the Album and then try to go back using the breadcrumbs in the Right upper corner clicking on Album itself it will not load the previous page.. it will just show the RuneAudio loading logo. Same for all the Other ones.
The Network NAS navigation is working though.
Just to let you know.
-Toube
Toube
Postby rern » 04 Nov 2018, 09:48
Toube,
There are 2 flac files the last *.cue points to, side1 and side2. If both exist, try split the side2 to another file with identical header lines then update the folder and try again.
By the way, since I've never used *.cue files, convince me if I should start using it.
Postby Beelzebassie » 04 Nov 2018, 10:43
How are those CUE-sheets formatted? ANSI or UTF-8? I've had some problems in the past with ANSI-formatted sheets.
@rern: If you rip CD's for archiving purposes I'd recommend using CUE-sheets; you can keep the images unedited, easily adapt pauses, play HTOA, etc.
Beelzebassie
