[Addon] RuneUI Enhancement
Postby Beelzebassie » 04 Nov 2018, 10:51
On the topic of CUE-sheets, let me take the opportunity to shamelessly pitch this idea again:
Beelzebassie
Postby rlsten » 05 Nov 2018, 18:35
rlsten
Postby Toube » 05 Nov 2018, 20:16
For the .cue problem. I just created a new .cue file with same information in UTF-8 format and deleted the old one.
Then it loaded the tracks just fine.
Toube
Postby rern » 06 Nov 2018, 10:57
Postby R101 » 07 Nov 2018, 14:38
Hi rern,
I often leave the playlist displayed, rather than the playback page, so have noticed a bug. The cursor sometimes sticks on a list entry and just keeps counting up the time instead of moving on to the next tracks in the list. Playback of listed tracks carries on normally. Any action which reloads the page restores normal working. I have not found any way to reproduce this yet - it seems random.
Edit: I normally use the Android app, so this might not affect other browsers.
There also seems to be a problem with updating sources. After making a change and clicking on update mpd library, "Updating Library" shows indefinitely. If I close the page and try again, it takes seconds.
Postby rlsten » 07 Nov 2018, 17:05
Hi @rern,
Many thanks for all your work on the UI Enhancements; they are working very well now for me. I just have a few questions about some possible tweaks:
1. The Power Menu has not included an option to Turn Off Display for quite some time. I was wondering if that could be added as an option again? If not, do you know what I would need to edit to add it, or would it screw up something?
2. I'm sure this has been asked and answered before, but where exactly does the cover art come from: a tag in MPD, Last.fm, and/or an image such as cover.jpg in the same folder as the music?
3. I'm curious why the index bar in the library no longer works on my system. Older UI Enhancement versions work both on a local screen and on a remote PC screen.
Thanks again,
Rod
rlsten
Postby rern » 09 Nov 2018, 15:19
Postby hondagx35 » 10 Nov 2018, 12:35
Postby rern » 11 Nov 2018, 03:42
Postby ceejayemm » 11 Nov 2018, 10:52
Rern
Could this be something you might consider for a future UI Enhancement update:
minimserver-supplied-radio-playlist-artwork-t6449.html#p25537
I posted it a while ago but got no further response so maybe it's only of interest to me ?
Chris
ceejayemm
